โOct-05-2014 08:21 AM
โOct-11-2014 04:58 PM
โOct-10-2014 02:33 PM
mkirsch wrote:
Contrary to what you think, aluminum does in fact corrode. Worst is when it's in contact with iron and you introduce a little moisture to the party.
Humid Louisiana, a little vibration to burnish the paint off the receiver and the shank, and a few weeks of not towing is all it takes.
โOct-10-2014 11:41 AM
โOct-10-2014 10:56 AM
โOct-09-2014 01:07 PM
mkirsch wrote:
A stainless or aluminum shank is not going to eliminate the rust on your hands, because your receiver is made of plain carbon steel, and is rusting. The rust will transfer to the shank, and on to your hands. Wear gloves, or wash up afterward.
Leaving your hitch shank in 100% of the time, regardless of what it's made of, is not a good idea even if it's adjustable and will fit in your garage. Even if the shank is stainless, that receiver is still rusting, and if you leave the hitch in long enough it will become permanently welded into the receiver.
โOct-09-2014 11:25 AM
โOct-09-2014 05:20 AM
โOct-08-2014 07:20 PM
โOct-08-2014 01:35 PM
โOct-08-2014 11:28 AM
โOct-05-2014 10:48 AM
Golden_HVAC wrote:
It seems to me that removing the hitch shank is something that I do when I am not towing, so that I do not hit the hitch receiver with my knees when not towing.
Why not have two hitch receivers and have the ball already mounted on each? So simple to switch between the two. We do that at work all the time, as our van tows a 2 axle trailer with electric brakes most of the time and 2-5/16" ball, while the smaller single axle trailer has a 2" ball mount. Two heights too.
Fred.
โOct-05-2014 10:28 AM
โOct-05-2014 09:58 AM
โOct-05-2014 09:46 AM
Porsche or Country Coach!
