New Andersen WD hitch
JBarca
Nomad II
Nomad II
A fellow camper bud showed me this. It's new and different.
Anyone using one?
Andersen WD hitches
A U-tube video with the factory guy explaining it. You have to get past MR Truck doing his intro. Interesting 5th wheel hitch too.
http://www.youtube.com/watch?v=xvM7mCnqmwo&feature=related
It looks like this
I'll hold my comments for a short while to not cloud your thoughts. Ideally we can find someone here using one to quiz them on it.
John
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10 RA, 21,000 GCWR, 11,000 GVWR, upgraded 2 1/2" Towbeast Receiver. Hitched with a 1,700# Reese HP WD, HP Dual Cam to a 2004 Sunline Solaris T310R travel trailer.
514 REPLIES 514
JBarca
Nomad II
Nomad II
Bruce H. wrote:
John,
Thank so much for your response--just the kind of informed feedback I was hoping for. You make reference to the new SAE guidelines for weight distribution. I googled it but so far haven't come up with anything specific to weight distribution. Can you provide me with a link? I most definitely want to be within the SAE guidelines.
Thanks again,
Bruce
Bruce,
Picked you note up during lunch. I will be out camping this weekend (yeh!) but will hunt it up when I get back if someone else does not post.
Ron Gratz may have this handy and post. I know he has referenced this before. Plus he is "King of the Links"! ๐Ÿ™‚
Thanks
John
Bruce_H_
John,
Thanks again,
Bruce
2012 Lance 1575 TT pulled by 2013 4WD Expedition with HD Tow Package
JBarca
Nomad II
Nomad II
Bruce H. wrote:
I adjusted the spring tension until the front fender was within 1/8", which amounted to 1/4" of spring compression. I am a newbie at this weight distribution stuff, but I am thinking that there may be a little too much weight distributed to the front axle and trailer axle. Would appreciate your input on this.
You will notice a 20 lb. discrepancy in the figures. Nothing changed in either the TV or TT that would cause that. I am surmising that the CAT scale weighs in 20 lb. increments and that maybe the rig was right on the bubble.
Am comtemplating another visit to the CAT scale where I measure and weigh each 1/16 increment of spring compression, up to 1/4 inch. This should give me the info need to "fine tune" the setup.
Hi Bruce,
Your spread sheet is great. Thanks for sharing. You have a smaller truck and camper but we can see what is going on at the axles.
The 20 lb difference you are seeing at the scales is scale error. It is common to see that much. Remember they also weigh 80,000# semi's with these same scales....
By your numbers your truck has took on 320# of the 400# of your TT tongue weight. And in your case the rear axle is holding the 320#.
I checked the Andersen manual that states this:
Andersen wrote:
The goal of the weight distribution system is to get the tow vehicle and trailer as level as you can. With that in mind, here is the OPTIMUM setting for most installations:
FRONT WHEEL WELL: the SAME or within 1" ABOVE the initial measurement you took on page 4
REAR WHEEL WELL: the SAME or LESS than the initial measurement (but not drastically less โ€“see next page).
If you are already within the above parameters, then tow your trailer for a few blocks to let everything settle and remeasure. If everything is good, then you are at the optimum tension for towing your trailer.
I highlighted the wording "The same" on the rear axle as "optimum". They are shooting for a level truck it seems. Level can be hard to do pending the truck especially if the rear axle in high to start with. I'm not saying level is not good, but more about what the weights are doing verses being level and you have the weights.
There are many opinions on what is proper WD on a truck and one size does not always fit all. From my experience I would not recommend you go to the "same" on the rear axle. That will push more weight up front and lessen the weight on the rear. With only 320# added to the rear axle that is the added weight to help rear wheels traction on slippery surfaces. Making that less may break free traction in some cases.
What does Honda say in your owners manual for what proper WD is for this specific vehicle? Some times they do and some times they do not. Does your truck receiver have a "weight distributing" rating? I looked up a 2006 Honda Pilot and on page 217 of the owners manual version I found is says something about a WD hitch. The weights of your TT seem to be under what Honda recommends for "other" trailers then a boat. So weight wise things look in line including your GCW.
If you follow the guidelines of the new SAE recommendation they want the front a little lighter then they use to. They are worried about oversteer. The concern is a heavy front may bite in so to speak and send the truck and trailer into jack knife faster when turning.
I would not add any more weight up front. A small amount less may help with the new SAE guideline. I would check your owners manual on a WD hitch and what is the sticker rating on the truck receiver. By what little they said on a WD hitch you for sure do not want to take off any more weight off the rear axle and add any more to the front.
Good luck and hope this helps. You provided an excellent weight chart. Congrats on this now you know what is going on with the WD part.
John
Bruce_H_
I have been following this forum with great interest and have decided to give the Andersen Hitch a try. Never had to use a weight distributing hitch with our Chalet folding trailer. We purchased a 2012 Lance 1575 TT in late 2011, and it will be towed by a 2006 Honda Pilot 4WD. The Lance has a GVWR of 3500 pounds, which coincides with the Honda's tow limit of 4500 for boats and 3500 for all other trailers.
So far we have had two 80 mile trips with the Lance. The first was without any suspension enhancement, and the Honda really sagged in the rear. Then had Timbrens installed, and there was considerably less sag and improved handling on the second trip. Still thought it sagged a little too much, and also would like the assurance of sway control even though there haven't been any sway issues with the Lance. So, decided on the Andersen.
The hitch is installed and have utlized the local CAT scale, measuring and weighing various configurations. The data is contained on the attached spreadsheet. Don't know how to attach a spreadsheet, so I scanned it and attached it as a photo.
Moderator edit to re-size picture to forum limit of 640px maximum width to avoid scrolling.
Mike_E_
Just briefly read this thread, and it looks like Anderson may have a winner.
Little bit of a bummer that it costs $499 when there seems to be alot less steel involved when compared to the benchmark Equal-i-zer or Reese Dual Cam.
If they wanted to shake up the market they could have priced it less than the two top dogs....oh well.:R
I'll be watching for some more real-world reviews.
Mike
ch47d99
Sounds like the ease of use and adjustment is a real bonus here. The Equalizer is a pain to adjust. I will be watching these reviews carefully.
zues
I would say the tongue weight on our trailer will be more. I added 4 6 volt golf cart batteries, and two bigger propane tanks to the tongue.
JBarca
Nomad II
Nomad II
Logisitc,
Thanks for reporting back. Looking forward to hearing your report after the long trip.
When your hitched up next time if you can take a few pics of the hitch setup and post would be great.
Good luck and happy camping
John
logistic
I received and installed the new Andersen no-sway hitch yesterday. The install was simple. It required none of the normal trial and error tilt adjustments I'm accustomed to with spring bars. I loved the WD setup; I literally dialed in the amount of distribution by turning two nuts until the front wheel well was a 1/8" higher than original unhitched height. It was a piece of cake.
I had two small issues come up, both caused by the location of my battery bracket:
1) Install required moving my propane tank mount forward about a 1/2 inch to create clearance for the frame mounting brackets.
2) I had to cut a link off each chain with a cutoff disc in my grinder. This is due to the relatively forward mounting position I used on the a-frame rails. Handling this issue is detailed clearly in the hitch instructions.
I took a 50 mile test drive that showed lots of promise. I had 25-35 mph diagonal crosswinds to contend with on the hwy. Sway control was smoother but still comparable to dual friction bars. I found the elimination of trailer bounce was excellent and more noticeable than I had anticipated. I'm leaving for 1000 mile trip on Friday, I'll check in next week with an update. Regards
2004 Keystone Cougar 294-RLS (6125 lbs/675 lbs dry)
2011 Ford Expedition EL XLT HD Tow
2012 Ford F150 S-Crew EcoBoost XLT Max Tow
Slowmover
zues wrote:
Our truck is a 2009 Dodge Ram Mega Cab diesel. Our trailer is a 1965 Streamline Duke. I do not know the weight, but the trailer is 24 ft long. There is no cat scale very close to us, so that is why I have not weighed the trailer.
Streamline called it at around 3,500-lbs with a 375-lb TW for a 25' empty. Have a neighbor with a Prince that he renovated/restored and he reported 4,250-lbs fully loaded for a month-long trip. With that in mind, that Duke might be at 4,600-lbs with a 580-lb TW.
1990 35' SILVER STREAK Sterling, 9k GVWR
2004 DODGE RAM 2WD 305/555 ISB, QC SRW LB NV-5600, 9k GVWR
Hensley Arrow; 11-cpm solo, 17-cpm towing fuel cost
ch47d99
Gallifrey, I will be interested to see your review as I have the same combo. My equalizer has worked well too, but you nailed its drawbacks. Plus the thing is a little heavy...certainly not a big deal now but somethign to consider down the road.
zues
Clanton24V
Glad to see someone else that feels the same as i did after the first use of the hitch.
Gallifrey
Well, I also decided to take the plunge and I just ordered the hitch. I have a short (90 mile) trip coming up next weekend, so hopefully I get it in time to try it out on the trip.
I have a trailer that has the coupler mounted to the bottom of the frame. As I'm thinking of the forces involved, I don't think this should matter much since changes in the vertical distance between the coupler and where the chain attaches won't significantly change the amount of horizontal force applied to the hitch.
Right now my tow vehicle is a 2005 Nissan Armada. The trailer is a KZ Spree 318BHS. I use an Equal-i-zer hitch and it works very well. I've towed it in all sorts of weather conditions without trouble. The only time I did have some problems with the wind pushing the trailer a bit, we pulled over for gas and I had a bit of trouble standing when I got out due to the wind. I didn't realize the wind was blowing quite that hard! So, we waited about 30 mins for the wind to die down and then continued on our way...very impressed with the hitch.
So, why am I interested in switching to this hitch? Quicker to hook up, no grease (which has ruined quite a few of my and my kids' shirts and pants), less noise, possibly less vertical bounce and, above all, perhaps less frequent tightening. I have to constantly re-tighten parts of the equalizer, especially the arm brackets which move about on the trailer frame quite a bit if I don't really stay on top of them (and still move a bit even if I do keep them tight!). So, hopefully the Anderson is much better in this regard.
I'll let you know how it works out.
JBarca
Nomad II
Nomad II
zues wrote:
We just got back from a 200 mile trip and the hitch worked great. The hitch is really quiet and smooth. The road going to our house is about 2 miles and really rough. With the old hitch, the truck and trailer would buck. Today coming home with the Andersen hitch, it was really smooth. I love this hitch.
Truck sitting in front of trailer getting ready to hook up
Front 39 9/16
Rear 39 even
Trailer hitched up without the Andersen hooked up
Front 40 even
Rear 38 even
Truck and trailer with the Andesrsen hitch hooked up
Front 39 13/16
Rear 38 1/2
Hi Zues,
Thanks for reporting back and the numbers. Glad the system is working well for you.
It would be helpful if we knew the year/TT make/model and the truck year,make, model,cab and bed size.
Trying to get a handle on TT length and hitch weight coupled to a what size truck and wheel base that the WD hitch is working on.
Would you by chance happen to know your loaded tongue weight?
Thanks and happy camping.
John
PS a side picture of the hitch hook up would be super.
