โJan-13-2012 05:35 PM
โJan-24-2012 06:46 PM
BenK wrote:
John !?!... you've got me !!!!
Cleaning out the garage and coming in to check this site, so apologize for the
quickie comments...
Well, lots of assumptions on my part.
Assumed the ball is held in there by a traditional nut, but will have to see
how they capture it
Thought a traditional coupler with a pawl, but in looking at the image...there
is no latch.
So how in the world did they get the ball past the interference fit?...but that
is another assumption...that the coupler has an interference fit for the ball
like these images:
so if traditional, then that pawl will take the forces...but...since not traditional
how do they keep the ball from coming off?
By interference, meaning that the coupler has a lower hemisphere smaller
in dia than the ball dia. The pawl moves out of the way to allow the
ball to move backwards and then drop out.
โJan-24-2012 06:18 PM
โJan-24-2012 06:01 PM
โJan-24-2012 09:09 AM
dougsee3 wrote:
I can not post a pic. from my phone.
If you look at the TT hitch were the ball fits into the top of the ball socket.
The trailer TT hitch would have to rise up away from the ball to put excessive force (or all of the force) against the coupler latch.
What the latch is really doing normally is preventing the hitch from lifting off the ball rather than taking all pressure from braking and in this case the chains forcing the latch against the ball.
โJan-24-2012 06:58 AM
โJan-24-2012 06:23 AM
โJan-23-2012 06:30 PM
โJan-23-2012 05:51 PM
red31 wrote:
Would this system be less stressful on the trailer's a-frame members?
โJan-23-2012 02:31 PM
Gallifrey wrote:Most likely, it wouldn't damage the coupler body itself, but may very well destroy the latch. A latch kit for a common, rebuildable coupler isn't much money and is easy to replace. Not all couplers are rebuildable. To replace the whole coupler, I charge $150-200 for labor, plus the coupler, $30-60, to come out to wherever the trailer is and do the job. Mobile welding rates vary by geographic area. Shop welding rates also vary in comparison to mobile rates.
Anyway, if someone were to try this hitch out and it did damage the safety coupler, any ideas on how much it would cost to repair or replace the coupler?
โJan-23-2012 11:41 AM
โJan-23-2012 11:08 AM
BenK wrote:I believe the new SAE J2807 Recommeded Practice for towing performance requires a SRW TV, operating at its GCWR, should be able to accelerate from 0 to 30 mph in 12 seconds. The corresponding acceleration, assuming it is constant, would be 3.7 ft/sec/sec or approximately 0.11 G. The force required to accelerate an 8000# TT at 0.1 G would be 880#.
Think there is another metric and that is during acceleration.
Would that then pull the ball away from the coupler back side to transfer the loading to the coupler front side?
How much is the force during acceleration and will that over come the tension of the plastic springs ?
Would there also be enough force to repeat this during the drive? Guess dependent on the frontal area of the trailer and other drag vs the TV pulling to a higher speedI believe SAE 2807 also specifies a TV should be able to accelerate its GCWR from 40-60 mph in 18 sec. The corresponding acceleration would be about 0.03 G. Again, not at all likely that the coupler would be pulling rearward against the ball.
With my setup and the controller leading the trailer braking, that would also have the trailer pull the coupler off the back side.Not sure what controller you have. Let's assume the leading "boost" is set to 20% of maximum TT braking force. That probably means the boost-related braking force would be about 10% of the TT's weight.
Also assume the contact area of the plate steel hole and the ball tail end would not work itself. That the contact area is sufficient to distribute that constant load change from working the metal contact area.I don't know what you mean by this, so I cannot comment.
โJan-23-2012 08:57 AM
โJan-23-2012 05:14 AM
โJan-22-2012 06:34 PM
โJan-22-2012 12:06 PM
JBarca wrote:Let's assume each of the two chains is pre-tensioned to 2000# and each chain is parallel to the longitudinal axis of the TT. The chains would be pulling rearward against the spreader plate with a combined force of 4000#. With the TT at rest, the tension in the chains would cause the ball coupler to push forward against the ball with a force of 4000#.
Chains towing the camper When the TV is stopped or rolling forward at low speed, the chains are pulling the camper. The chain force is high enough that is it pulling the camper forward and seating the tow ball into the latch side of the ball coupler. Clearance exists between the ball sphere and the front part of the coupler that normally pulls the camper. The rolling resistance of the camper on the 28.3" OD tires on concrete or black top is less then the chain force under these conditions.
Tow ball towing the camper There may be a point where the wind drag on the front of the camper or up hill (gravity) loads increase enough that the TT drag is higher then the WD tension in the chains. In this case the TT would shift backwards by the clearance in the coupler when the wind drag force overcomes the WD chain force. The tow ball leaves the coupler latch and now becomes seated into the front part of the ball coupler. The TT is now pulled by the ball coupler.Now, let's assume you actually could tow a 10,000# TT up a 6% grade at 70 mph. This would result in an additional towing force requirement of 600#. The previously calculated forward force on the ball would be reduced from 3000# to 2400# -- still sufficient, IMO, to preclude any "banging" of ball against coupler.
What we do not know yet, is on a 1,400# TT tongue weight, 9,200# GVW TT does the wind drag or up hill drag ever get high enough to let the ball coupler tow the camper? And any guesstimate on what speed that may be? I picked those weights only because they line up with my camper. The issue can occur under other TV and TT combos as well.IMO, if each chain is pre-tensioned to 2000#, it is highly unlikely that the combination of wind drag, uphill drag, and rolling resistance will ever result in the ball pulling forward against the coupler.
The high load on the coupler saftey latch is a large concern. If the TT seats and reseats back and forth constantly as you tow down the road, the fatigue on the coupler saftey latch is something to think through.IMO, the TT will not seat and reseat back and forth. However, I do think that coupler manufacturers should be asked to comment on any possible consequences of operating with the coupler constantly pushing forward against the ball.
IMO, your previous post gave a excellent analysis of how much WD torque might be generated by the Andersen hitch. The new hitch is rated for 1400# tongue weight. I doubt that a combined chain tension of 4000# would provide sufficient WD torque for a 1400# TW. It would be good if Andersen could provide some before and after axle load data.We understand how it has the ability to distribute weight. How effective it is and sensitive it is is another question.
