Ok the manual is just a generic Onan I assume,
It says run for 2 hrs every month half load.. do you guys do that ?this one has 110 hrs
I did chg the oil and have started it but not let it run too long.
Also it says 459 hrs to chg the fuel filter.. I don’t even see one.
And it says drain the carb bowl to store and pull the plugs out of the exhaust and run it to blow junk out, do you guys do that too ?
I would think if I add Stabil to the fuel run it for an hour with load, shut it down and leave the fuel I. The bowl would be better ?
2013 Winnebago Sunstar 26HE
