Oxygenics - complete water shut off or still a trickle
kopy_kat
confused by the ads--does the new version with the push button shut the water off completely, or just slow it down to a trickle like the original equipment cheap plastic shower head...??
thanks.\, Larry
2013 Flagstaff 8528ikws---"Camp MiMiPaPa"
9 REPLIES 9
Searching_Ut
As I recall, in many, if not all areas of the US the "trickle" is a code requirement which came about around the same time that the pressure balancing shower heads became required. It's to help keep the temperature consistent. If the item is designed to work in a building, it will almost certainly not shut all the way off.
2015 Ram 3500 Laramie CTD, 4X4, AISIN, B&W Companion Puck Mount
2016 Heartland Bighorn 3270RS, 1kw solar with Trimetric and dual SC2030, 600 watt and 2k inverters.
bikendan
Pauljdav wrote:
I like the trickle. It keeps the water from being super cold or hot when you turn the water back on.
Ditto!
dan-nickie
tvman44 wrote:
Does the Danco shut off the flow completely? ๐Ÿ™‚
It still trickles a little.
I like it that way so the water does not get as hot while valve is closed.
Dan and Nickie
2014 Forest River Berkshire 390RB
Water-Bug
dan-nickie wrote:
For those with the older models without the water cutoff included, I found this at Home Depot.
DANCO Shower On-Off Push-Button Flow Control
X2
Pauljdav
wtravlr1
the one i bought did not shut off the water completely (see Amazon reviews), new one is a trickle if sold in the bath section. you have to get a shut off valve, took some searching many valves listed as shower shut off on the front of the package only to find on the rear it said "does not shut off water entirely" seems as if the new valves mostly are tickle valves. There are other valves on Amazon that have 100% water shut off.
tvman44
Papa Bob
Husky 16K hitch, Tekonsha P3,
dan-nickie
Dan and Nickie
tvman44
Still a trickle. ๐Ÿ˜ž
Papa Bob
