Pic of wrangler with tow bar base plate installed?
rctoyguy
I am considering a class C and using my 4 door wrangler as a toad since I already have it and they are supposedly easy to tow.
I'm not crazy about the idea of permanently attaching a baseplate to my daily driver - especially if it's obvious when not being tower (or if there is any negative affect on off-road use).
Can anyone show pictures of a newer model Wrangler with base plate installed? What does it do to the front of the jeep?
2013 Ram 2500 Laramie Longhorn 4x4 CC CTD
B&W Patriot 16K
2017 Forest River Surveyor 299RLOK
15 REPLIES 15
MyakkaTT
Roadmaster Base Plate and Blue Ox Tow Bar..
2002 Winnebago Itasca Sunrise 32V
Towing a 2013 Jeep Wrangler
My Wife: Dawn
Myself: Scott
Our Dog: Our new Fur Kid, Kylee
Our Photos
[purple]"Quietly Making Noise"[/purple]
Y-Guy
Moderator
Moderator
Thunder Mountain wrote:
Tomken made in Buena Vista, Colorado.
Thanks!
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
FIRE_UP
avan wrote:
Actual baseplate is not visible however at the left barely visible is one point of attachment for towbar, then the connection for the ReadyBrake or Autostop surge brake (silver), then the attachment for the breakaway brake cable (red) and not visible the electrical connection and then to the right is the other towbar attach point. Connection points for the breakaway cables are out of sight.
avan,
I don't know if you know it or not but, it appears that your bumper is a Smittybuilt SRC. Just guessing. And, they make a few models of that bumper. For a few dollars more, you could have had the welded on D-ring tabs (3/4" x 2")installed. And, Blue Ox makes adapters for that style of D-ring tabs on many of the aftermarket bumpers.
That way, there's no need for a base plate of any type. The tow bar simply attaches to the D-ring tabs for towing.
Then, when done towing, the tow bar is removed and, the D-rings are re-installed and, you're ready for the trail. Just some info.
Scott
P.S. Below is our Jeep with a Warn front bumper. On this model, there are dual, 3/4" tabs welded on both sides. Warn builds them either way, single or dual. Blue Ox made the adapters for our Blue Ox Aladdin and, it fits right on that bumper. The adapters were only $49.00.
My advice for any potential Jeep toad owner, if you're even "thinking" about an aftermarket front bumper, have the tabs installed or, purchase a bumper with the tabs already ON and, use those for towing so you can eliminate the need for a base plate. You automatically kill two birds with one stone that way.
Scott and Karla
SDFD RETIRED
2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
Thunder_Mountai
Here is my solution for a Blue Ox tow bar. This is a custom bumper.
Which bumper is this? It doesn't appear to be the LOD or Rock Hard, which has me curious. Thanks!
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
dahkota
We also have a custom bumper (Rockhard) and love it. Doesn't interfere with ground clearance, looks great, and gave us what we needed to install a winch.
2015 Jeep Willys Wrangler
2014 Fleetwood Bounder 33C
States camped: all but Hawaii
more than 1700 days on the road
Y-Guy
Moderator
Moderator
avan
Confession. Daughter if forcing me to admit that the jeep is her toad and that mine is the more mature person's Saturn
www.putt10.net
Thunder_Mountai
Here is my solution for a Blue Ox tow bar. This is a custom bumper. I had the recovery ring hard points replaced with Blue Ox hard points during fabrication. The four bolts are attached to the Wrangler frame using the stock bumper attachment points. Recovery rings will not fit in the gap between the Blue Ox mounts. So, I ground about 1/8" off one side off the recovery ring.
2018 Rubicon
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
puttd
Avan, nice Jeep.
avan
www.putt10.net
RichNewcome
Here is a quick picture of my 2013 Wrangler with a Blue Ox baseplate and Ready Brake cables. The inside ends of the cables disconnect from the brake pedal allowing enough slack to hide the outside loops. Looks like I'm overdue for some rust cleanup and black touchup paint though.
Trackrig
I thought I had a better picture, but this is all I can find of my 2002 with a Roadmaster set up. All of the hardware you see in the photo pulls off with two pins leaving just the base plates bolted to each frame rail which aren't going to be in your way at all. Holding down the Control key and hitting the + key several times will let you blow up the picture some
Bill
rctoyguy
I will look there again but the only pic I saw (on the install instructions) didn't show much.
B&W Patriot 16K
K_Charles
Go to blue ox and you can find a pic of most anything with a base plate
