Putting carpeting under mattress
afinepoint
The surface beneath our mattress is plywood/pressed board. The exposed edge is carpeted. I plan to carpet the entire surface for additional sound proofing, insulation and to prevent touching a splinter nursery.
I can't see any issues doing this and presume the manufacturer didn't do it to reduce costs.
Reg
Tow vehicle: 01 F350 7.3L CC Lariat 4X4 dually, 220 amp alt, lit by PIAA & KC, thrust by Dp tuner, braking courtesy of ART cryogenics and PF pads, on board air, lane clearing by Nathan Airchime train horns, car catcher by Road Armor. Trailer: RPM M-26FBS
17 REPLIES 17
scbwr
If you used a thinner carpet, you may be able to cover the edge of the plywood and staple it to the underside which extends beyond the storage area under the bed. I've never thought of using carpet to do this. I have thought of glueing insulation board to the underside of the platform.
On a non 4 season trailer, has anyone determined whether there is any benefit to adding insulation board to the back of storage compartment doors?
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
Margos_
What a great idea. Never would of thought of it. Will put a little padding under the mattress also.
SBradley
http://www.greatmats.com/foam/foam-mats.php
These are 5/8 inch thick they interlock, provide a non slip surface, insulation, and sound proofing.
I used this under our bed, I cut one side to fit perfectly, I can take them out to clean.
S Bradley
Navion IQ 24V
