"Vintage" Reese Dual Cam WDH
Massey16
Hi all!
I happend upon a WDH at a garage sale for $5 and just couldn't pass it up! I didn't really know what I had until I did a little research. Turns out I have the original ("vintage") dual cam set up from Reese.
After I contacted Reese about how to figure out the rating of the bars, I have 750# bars. This will work out well because my current TT is 7500# max.
I have a few questions before I start to use this system. Can I use the adjustable shank that I have for my traditional WDH? Any advice on set up? Most of the posts are for the newer style.
Thanks!
25 REPLIES 25
BarneyS
As long as the U bolt can move forward or backward to make adjustments then YES you have enough clearance.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
Massey16
Looks like there is just enough clearance???
Massey16
BarneyS wrote:
Other than that, there is no special trick or problem installing the old style Dual Cam system. Hopefully, you can raise your propane tank to allow the U bolts to fit under it. I used longer sheet metal screws through a 1/2 inch or 5/8 in nut under the propane tray to act as a spacer.
So, I picked up my camper (yes, I realize its almost the end of July) and realized what you were trying to point out. I'll take some pics tonight to see if I can even get the U bolts in there. This may have been a pointless discussion.
Francesca_Knowl
Thanks, Barney- downloaded and saved!
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
BarneyS
I didn't realize thzt a person needed to sign in to get the file. Sorry.
Try this one instead.
Barney
Not towing now.
Francesca_Knowl
Wow- thanks for the heads up to the instructions, Barney. The link goes to a Dropbox sign in page- do I need to be a member to access the PDF?
BarneyS
Massey16 and Franscesca,
If either of you need the installation instructions for the old style Dual Cam system, I have them on my dropbox account here where you can download them in PDF format.
By the way, I always used a small bit of Vasoline on the cams when I had the Dual Cam system. It made it very quiet and did not seem to affect the sway prevention at all. I used the system for quite a few years before purchasing my Hensley hitch.
Barney
Edit to fix URL for Dropbox.
Not towing now.
Francesca_Knowl
BarneyS wrote:
Francesca,
That hitch is an old style Reese Dual Cam hitch that combines WD with very effective sway control. That is what those "cams" are for.
Barney
Thanks, Barney!
I asked because my Father-in-Law gave us a setup exactly like this one. We've wondered if it might be just what we need to pull the 25 foot trailer we recently acquired to fill in when more folks want to come along than can be accommodated by our just-us camping setup.
Sounds like it might be just what the doctor ordered.
Massey16
Thanks again for the insight!
I'm picking up my camper from storage this weekend, so I'll have a chance to get it all set up. I borrowed a caliper from work so I can make sure it matches up with the head/shank ( sorry, didn't quite have the jargon down). After that, I'll get weighed. You could be right that I'm heavier than I thought.
I'll post some pics and numbers when I get it done. Thanks!
BarneyS
Francesca,
Barney
Not towing now.
BarneyS
Massey16 wrote:
Snip...
The shank that came with the hitch is not adjustable as you can see from the picture above. Can I use this one instead?
Yes, you should be able to use that one as long as you can get the old one off of the head. I was not able to see what it looked like in the picture other than it looked quite rusty. :W
Edit: I see you were asking if you could use the pictured shank and hitch head combined. Yes you probably can if the trunnions on the bars match up to the same size of the newer hitch head.
When setting the hitch up, I should take my measurements and get it all set up while leaving these loose?
I would attach it as normal, draw up the bars so there is the required pressure on them but don't torque down the U bolts on the mounting plates completely. Leave them just a bit loose and drive around as I mentioned. Then when you stop in a straight line get out and tap them in the correct direction to center the bars on the cam. They will snap into place. Then torque the nuts on the U bolts all the way.
And then tap them into place? Just trying to get it all down before I attempt this.
Yep!
Also, I know the bars may be light in the long run, but we don't put much in the camper and I doubt my tongue weight is near 750#. Only way to tell is to get it set up and head to a scale.
Lastly, anything to replace on these other than hardware? I was going to remove all the bolting, blast it all, paint it, and reassemble.
That is one possibility but you can also replace the brackets quite cheaply or use the ones that you already have from your old hitch. They are just the standard snap-up brackets.
Also, those bars should be ok IF you tongue weight is not above 750lbs but I would not rely on a guess for that. Most people are quite surprised when they actually weigh their rigs and find out the "real" tongue weight and total weight. I would get to a scale sooner rather than later.
Barney
Not towing now.
Francesca_Knowl
Hope no one minds a question from the peanut gallery:
Does this "vintage" w/d hitch have built in sway control, or does that have to be added?
Massey16
I'll measure everything up to make sure they match up well. Anything else to do but scuff the pieces up and paint?
dodge_guy
Just make sure the bar ends fit into the hitch head with plenty of surface for the bars to not fall out of the head when under tension.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
