Reese Steadi-Flex Vs Reese Pro Series with Sway Control
nsbell
Has anyone had experience towing with the Reese Steadi-Flex Hitch?
Is it worth the extra money verses buying the Pro Series with Sway Control?
Does the Steadi-Flex Hitch perform as well on weight distribution and sway control?
Thanks
2 REPLIES 2
Bosco122
I've used the Steadi Flex for almost a year now pulling 8k travel trailer. This is my first TT so I have nothing to compare the Steadi Flex to. I'm very happy with the Steadi Flex. Simple design and easy to use. Great sway control too. So far zero issues.
Hannibal
No experience with it but here's a demonstration of it in action. It looks like it's based on the same concept as the US made Equalizer 4 Point hitch but with pads on the frame brackets. The pads look to be about $80 when the time comes. A lot of Reese products are now made in China. Don't know if this one is or not.
https://www.etrailer.com/Weight-Distribution/Reese/RP66559.html
Too bad they don't do a comparison video with several of the top hitches.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
