Short Term Freezing Weather Tips?
DallasSteve
I'm in the Rio Grande Valley (South Texas) and we are forecast for about 2 days of freezing temps Monday and Tuesday. The low right now is expected to be around 26 degrees. We are in a motor home with no skirting outside. I will keep the house temp at least 70 degrees through the night and I plan to keep the cabinets open and drip the faucets. Am I safe from frozen pipes or do I need to shut off the water and drain the pipes during the nights? Have you actually been camping through similar temps?
2022 JAYCO JAY FLIGHT SLX 8 324BDS
2022 FORD F-250 XL CREW CAB 4X4
All my exes live in Texas, that's why I live in an RV
17 REPLIES 17
JKJavelin
If you have an enclosed underbelly, disconnect the hose going to the rig, let the furnace run overnight (60s ok) and don't worry about it. Even without the furnace upper 20s for a few hours won't penetrate.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde AllTrek 4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017-2022 555 Nights
2023- 106 Nights
bgum
Disconnect and drain hose after filling fresh water tank. Operate off fresh water tank while freezing. Open cabinet doors to allow heat to get to pipes. Run water heater to heat water in tank. Make sure propane tank is full. Run small electric heater to supplement coach heater. Pull slides in if possible to use coach while in. Empty black and grey tanks. Camped as low as 12 degrees Fahrenheit.
26 is not really that cold but you never know , it is expected to be 15 here.
Second_Chance
I'm seeing a lot of posts on the topic from folks in Texas right now (we're Texans but not in Texas at the moment). If you run the main furnace rather than space heaters, it should keep the basement from freezing. We're in a fifth wheel rather than a motorhome, but we've weathered temps as low as 10 - 11F with high winds and survived.
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
