Hi L-B travelers welcome to the forum. When you say your RAM has a brake control system are you referring to the system that controls the trailer brakes? Or are you referring to a built in sway control using the trailer brakes. If you're not too sure, just hit the "Reply to topic" button at the bottom of the page and post the year of your truck and we can look it up and possibly see what kind of system you have.
But to answer your question, yes I believe you should be looking into some kind of sway control. There are many different types of sway control on the market ranging from a $50 add on sway bar to a $2,500 Hensley or Pro-Pride.
Be aware that Sway is typically caused by one of two factors. Too much weight behind the trailer axles giving your trailer a light tongue weight. Or driving too fast. Probably the best thing to do is to load the trailer up, put the heavier items in front of the axles and go camping to see how it all pulls.
The trailer will always move and wiggle from time to time behind your truck, that is normal. But if you feel it's starting to oscillate too much or it actually starts to sway back and forth (you'll know it when it happens) Slow down. If it's just a minor sway that makes you uncomfortable just lift your foot off the accelerator and slow down. If it is a big uncomfortable sway you need to use the slider switch on the brake control in the truck to apply the trailer brakes.
If sway occurs do not speed up to try to tighten the link between the truck and trailer, you'll only make things worse. Manually apply the trailer brakes which will tighten the link between the two and slow you down at the same time.
Oh and also be aware, we love to spend your money. So take everything with a grain of salt and consider carefully before you go spending money on things we recommend.
