โJul-19-2013 12:41 PM
Firestone/Bridgestone wrote:
The tireโs speed rating is void if the tire is repaired..... snip for clarity.....It should be treated as a non-speed rated tire.
โJul-26-2013 07:40 AM
โJul-26-2013 06:41 AM
โJul-25-2013 01:06 PM
โJul-25-2013 12:38 PM
โJul-25-2013 11:56 AM
Goodyear wrote:
From: goodyear_cr@goodyear.com on 07/25/2013 01:13 PM
Sent by: Goodyear Tire & Rubber Company Consumer Relations 728 1144 East
Market Street Akron, OH 44316 Voice #: 800.321.2136 Fax #:
330.796.6829
Mr.,
The max load is 1,360lbs at max 50psi.
Industry standards dictate that tires with the ST designation are speed
rated at 65 MPH (104 km/h) under normal inflation and load conditions.
โข Based on these industry standards, if tires with the ST designation are
used at speeds between 66 and 75 mph (106 km/h and 121 km/h), it is
necessary to increase the cold inflation pressure by 10 psi (69 kPa) above
the recommended pressure for the rated maximum load.
Do not exceed the maximum pressure for the wheel.
Jennifer - Consumer Relations
To: goodyear_cr@goodyear.com
cc:
Subject: Contact Us request from www.goodyear.com
A Goodyear website user has submitted a request through the corporate
contact form. Please address the concern accordingly.
Name:
Email:
Phone:
Address:
, 0
Message:
Looking for ST trailer tires. What is the status of your Document PSB
#2011-13 with Subject: Tires for Trailer Use Only: General Information ?
What is the max load and psi of your Marathon 175/80/R13 between 66 and
75mph?
If you are not the correct recipient, please notify the Goodyear Global Web
Operations team of the email error and we will update our website contact
list.
โJul-24-2013 10:11 AM
jadatis wrote:
... and that would prove your 45 psi used is ok. But correct me if I am wrong.
message wrote:
HTH;
John
โJul-24-2013 04:24 AM
โJul-24-2013 04:11 AM
fj12ryder wrote:
Not to hijack this thread, at least not too much :), but how exactly will "low tire pressure" be proven to be the culprit? It's pretty much impossible to tell "after the fact" so any speculation is just that: speculation.
โJul-24-2013 02:25 AM
full_mosey wrote:CapriRacer wrote:
Just an FYI,
There's a provision that isn't well publicized about ST tires (LT tires, too) that you can over-inflate them 10 psi and that allows you to run up to 75 mph. If you also reduce the load by 10%, then you can run up to 85 mph.
So, yes, it is permissible to exceed the inflation pressure written on the sidewall - but only by 10 psi.
Can you do the math for me?
I have a single axle with ST175/80R13 50psi 1360lb rated tires. My heaviest wheel is 1060lbs. I run the psi from 45-50 now.
What pressure would allow me to travel at 65-75mph?
HTH;
John
โJul-23-2013 09:27 PM
โJul-23-2013 08:29 PM
โJul-23-2013 08:04 PM
โJul-23-2013 05:14 PM
pronstar wrote:Francesca Knowles wrote:
Someone please correct me if I'm wrong, but the way I understand that "increase the air pressure for higher speed" thing is that it refers to recommended pressure for the load as a baseline.
Taking as an example the first tire in the chart below, if installed in a position carrying 1530 pounds of weight, 40 pounds of pressure is "correct". But running it at its 50 pound maximum would allow for the higher speed.
I interpret that to mean that if one's running it at 50 pounds already, one's good for the higher speed....is that correct?
You are absolutely correct.
The "general consensus" for many posters on RV.net is that all trailer tires should always be maxed-out for psi, but in reality I believe they should have their pressures set according to load, as the MFR recommends, just as we do with any other tire.
โJul-23-2013 05:11 PM
Looks like my (most recent) question got lost in the shuffle...it had nothing to do with running over the max tire pressure as given on the tire sidewall. Asking your forbearance, I'd like to repeat it here in hopes of getting an answer
Thanks, I hope!pronstar wrote:
See that's the problem...
On the one hand, we're "supposed to" run ST tires at max pressure at all times.
On the other hand, we're told we can safely exceed 65 mph if we increase tire pressure.
It's a moot point when the tire pressure is already maxed out.
