Tow Dolly 2019 Honda Ridgeline 2WD
DAS26miles
I have a 2009 Honda Ridgeline and really wished I could take it make it a toad. But because of the AWD, wheel speed sensing and weak front end , it can't be towed. I see Honda has brought it back and offers a 2WD. Has anyone either tow dollied or 4 wheel down towed one?
1 REPLY 1
Y-Guy
Moderator
Moderator
From the 2018 Owners manual
Your vehicle is not designed to be towed behind a motorhome. If your vehicle needs to be towed in an emergency, refer to the emergency towing information.
Emergency Towing
2WD models Wheel lift equipment
The tow truck uses two pivoting arms that go under the front tires and lift them off the ground. The rear tires remain on the ground. This is an acceptable way to tow your vehicle.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
