โMay-11-2013 03:16 PM
โMay-13-2013 10:16 AM
โMay-12-2013 04:19 PM
bhooperdoski wrote:Dutch_12078 wrote:
When I wired our RAV's for towing 4-down, I connected the diodes to the rear light wiring at the driver's side front kick panel. It took a bit of hunting and testing with my meter to find the correct wires, but they're all there. I chose to fully wire the lights so the RAV's lights work exactly the same as the separate brake and directional lights on our coach
Dutch, some questions:
1) When you say the driver's side kick panel you're talking about the plastic panel to the left of the clutch pedal, right?
2) Are there any tricks to removing the kick panel?
3) Do you remember any of the color combinations of the wiring you tied into?
4) How did you get the the flat wire into the area where you made the connections?
5) Are there any tips and/or tricks or anything else you can add to make the job less painful?
Thanks.
โMay-12-2013 03:36 PM
โMay-12-2013 09:51 AM
vermilye wrote:
I have no idea how the side panels of a 1998 RAV4 compare to a 2008, but this page describes the process of installing the "Trailer Wire Harness". This is for setting up a RAV4 to tow, not for being towed, but is does describe how to remove the panels to get from front to back.
I ran this, along with a charge line & brake controller line using information from this page setting up my 2010 RAV4 for towing my 17' Escape trailer. Took most of a day to make the run.
โMay-12-2013 09:26 AM
โMay-12-2013 09:10 AM
Dutch_12078 wrote:
The wiring kit you linked to is intended for hooking up a trailer to your RAV, and will not work the other way around. The 4 lights to 2 lights adapter will not work in reverse unless it's different from the one I have for my utility trailer that's towed by my 2002 RAV4. When I wired our RAV's for towing 4-down, I connected the diodes to the rear light wiring at the driver's side front lick panel. It took a bit of hunting and testing with my meter to find the correct wires, but they're all there. I chose to fully wire the lights so the RAV's lights work exactly the same as the separate brake and directional lights on our coach. When we bought our current 2011 RAV4, i did exactly the same installation again. It saved running wires all the way to the back.
โMay-12-2013 08:30 AM
โMay-12-2013 05:03 AM
The Fatman wrote:
$23.00 at Wal-Mart magnetic towing lights with 4 pin hook up keeps it simple
โMay-11-2013 07:01 PM
โMay-11-2013 06:15 PM
โMay-11-2013 05:47 PM
โMay-11-2013 04:58 PM
โMay-11-2013 04:23 PM
