Towing Honda Element 2011 EX
moose888
I plan on flat towing our 2011 Honda Element does any have any suggestions before I start towing the Element. I know they say it can't be towed but it's the same drive train as the CRV.
I have a Roadmaster Eagle 8000 tow bar but I need to get the base plate. Anyone towing a Element comments would be a great help. One question I have is what type of braking system are you using .
4 REPLIES 4
inflt48
I drive a 2010 EX, Blue Ox plate and bar,no brakes (bus weighs 47k, Honda less than 4k). No problems. I follow the directions for the earlier years, and it seems to work fine.
Big_Katuna
I have about 80k miles left on the warranty. I have had five Hondas for about half a million miles or more, tens and tens of thousands of miles towing them and never had one mechanical issue in or out of warranty.
That is why I drive Hondas.
I figure if I DO have a problem, I will take the baseplate off which I can do on the side of the road in about 40 minutes.
My Kharma ran over my Dogma.
Bumpyroad
do you have any warranty left on the element? if so I wouldn't tow it myself if Honda says NO. I used a brake buddy when I was towing a toad.
bumpy
Big_Katuna
I tow an 11 EX Element. No brakes yet. Probably wont unless I go 0ut west. I have a Ready BRute setup and I installed it on our 04 Element. Easy install. I installed a Demco baseplate myself. Easy install, no drilling.
