Toyota dummy key
T_bone1
I use a non smart key to unlock the steering wheel in my 2015 Toyota when towing..I was told by someone the other day that this will cause big problems with my Toyota computer..I did the same thing with my 2013 Toyota for a year with no adverse effects..Do es anyone kn ow if this is a problem? I will ask my Toyota expert tomorrow..Thanks..
2017 Georgetown 329S
2015 Toyota Tacoma toad
12 REPLIES 12
T_bone1
lryrob9301 wrote:
T bone wrote:
lryrob9301 wrote:
T bone wrote:
I just tried this on my Toyota and it works..The only drawback is that the Brake Buddy needs the acc to be on for power..
Very simple modification, go to an auto parts store and buy a new power port and install it in a convenient location. Wire it directly to the battery with an in-line 10 AMP fuse. As a mater of fact, I believe Brake Buddy makes a kit for just this purpose.
That is a planned project!!
lryrob9301
T bone wrote:
T_bone1
lryrob9301 wrote:
Your Toyota "Xpurt" is misinformed about the use of a plain key.
You are aware that most Asian imports since 2009 model year do not require the key to be in the ACC position to unlock the steering. Try this:
1 insert key and turn to ON position
2 turn key to the OFF position
3 DO NOT REMOVE THE KEY
The steering will stay unlocked until the key is REMOVED from the ignition switch.
T_bone1
Heisenberg wrote:
So, off topic, you got a new truck after the bad driver incident?
Yes,it is almost an exact twin of the destroyed one,I already have it all set up to tow,,
Bobbo
Not the OP, but I bet his reason is the same as mine. The valet key will start the car, so if someone wants to steal it, they can unhook and break a window.
Bobbo and Lin
view2a_thrill
Why do you use a non-smart key instead the valet key?
Heisenberg
2013 Winnebago Sightseer
2017 Colorado
Johno02
If the car ran after the first time you used it, You are probably OK.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
Dutch_12078
We've been using the key turned off but left in place routine since we learned about it not long ago. Thanks, Leroy! :B But we use a non-smart key that's had most of the head cut off and is painted flat black. Looking in the toad windows, it's very difficult to tell there's a key in the slot.
Dutch
2001 GBM Landau 34' Class A
lryrob9301
1492
Moderator
Moderator
Moved from Technology Corner
Bobbo
I hope it is OK. I have been doing that for 4 years with my Subaru.
Bobbo and Lin
