Jun-21-2015 06:54 AM
Jun-21-2015 08:07 AM
Jun-21-2015 07:25 AM
myredracer wrote:
I assume that you have the amp. on only when using antenna, that antenna is up and aimed for max. signal strength? (Sorry for asking but just in case.)
Start by checking co-ax connection on roof at antenna and at the rear of the amp. plate (will have to pull from the ceiling a bit to inspect). Can be loose sometimes or connector not installed correctly. Is this something new or has it been okay up until now?
Is it perhaps just a weak OTA signal where you are? If a weak signal, you can install a Winegard SensarPro signal finder which boosts the signal more than the standard one and also a Winegard Sensar IV to the existing antenna.
The two TVs in our Spree work just fine together.
Jun-21-2015 07:19 AM
