Want to replace faucet at kitchen sink
36guy
Are the faucets in an rv the same as residential units? The faucet in my class c leaks and I'd like to replace it. Thanks.
20 REPLIES 20
Lwiddis
"If you spend much time doing dishes,..."
And, 2oldman, who do expect do the dishwashing except the MAN of the RV?
rbrand
I picked up one at Ace and it was just fine. Just measure your centers to make sure it matches.
The less you plan the more options you have.
Currently with a 26' Forest River Class "C"
Ex Navy Diver
Ex Archaeologist
Ex Museologist
Actively retired
NEOK
We replaced ours with a Delta residential faucet last year. Just make sure the new one will fit the holes where you removed the existing one. Also, if you want to go with a pull out residential faucet make sure there is adequate room und the counter and sink to hold the hose for the faucet. THe hot water tank, water supply lines and drain pipes under our sink did not leae enough room for a faucet with a pull out hose.
neok
2009 GMC 25000HD Short Bed 6.0 Gas Engine Crew Cab SLT 4x4
2008 Bigfoot 15C9.5FS
Torklift Talons, Fastguns, Stableload Quick Disconnects, Superhitch & SuperTruss
2oldman
If you spend much time doing dishes, that faucet is very nice. Tall, and swings, and sprays.
phillyg
Chances are it's similar. Take the old one to the home center and have the help compare, and if necessary, locate adapters that will work.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
2oldman
You can choose any resi unit as long as it fits. We've all done that!
