What if trailer is over 15% TW?
brianosaur
Just wondering if there would ever be towing problems if a TT is loaded too far forward and over the ideal 10%-15% TW?
I know overloading to the rear of a trailer axels, and having under 10% TW, potentially will cause sway.
Assuming a trailer is UNDER its GVWR, the WDH is UNDER max wt, the TV PL & RGAVR is UNDER max wt, TV is level & front fender at an identical height as if no trailer attached -
Would there ever be towing issues if all specs were within limits but the TW was 20%-30% or even more?
Is 10%-15% just a 'sweet spot'?
15 REPLIES 15
ScottG
Probably nothing, more tongue weight usually means better handling as long as the TV can handle it. Lots of boats are way heavier in front.
