โMay-18-2021 12:04 PM
โMay-20-2021 10:03 AM
โMay-20-2021 09:42 AM
Matt_Colie wrote:
Kirk,
#1 It should be safe, but the flame may deposit soot on the bottom of the oven bottom plate and the bottoms of pots used.
#2 The problem is the lack of oxygen. There is probably (I don't know your specific hardware) an air adjusting collar near the jet of each burner assembly. You could slide it (there is usually a screw that holds it) more open and the yellow flame tips should be reduced. The flame size will still be larger than expected, but that should not matter.
If you plan to get back below about 5KMSL, and that air sleeve is still set for 9+KMSL, the burners may go lean. They can go too lean to stay burning. This is not a good thing.
Matt
โMay-20-2021 08:45 AM
rvexodus wrote:
Thanks folks and Matt for you explanation. All makes sense.
I did relight a couple more times and did notice there were a few flames that had orange tips .... not all across the long over burner but in some places there were orange / yellow flames. This I know to be an oxygen issue. I do have a suburban stove SRNA3. I believe there are a few variants of this model. Mine has the stainless front as well as elec ignitor. I know this stove has a couple of different manufacturers of the manifold as well.
I'm guessing this may be more of an LP (everything on the floor) butane propane mixture issue as I'm 84.3% certain this issue occurred after we refilled our tanks.
#1 question. Is this safe and what should I do about it if anything? #2 Is the problem oxygen or fuel or a combo of the two?
Thanks again ... interesting topic ....
โMay-19-2021 10:34 AM
โMay-19-2021 06:13 AM
โMay-18-2021 07:42 PM
โMay-18-2021 05:50 PM
โMay-18-2021 04:24 PM
โMay-18-2021 02:31 PM
โMay-18-2021 01:22 PM
