Jan-01-2019 03:48 PM
Jan-13-2019 10:48 AM
Jan-13-2019 10:29 AM
Jan-05-2019 06:52 PM
CA Traveler wrote:Harvard wrote:I would disagree. ANY GROUND FAULT exceeding the standard safe limit of 5 ma is a safety issue waiting for a opportunity. The potential for animal or human significant shock should always be considered a issue IMHO.
I just realized this RV is a trailer and not a motorhome. It matters because any trailer jacks that touch earth ground are going to provide a parallel ground path to the wired GREEN ground wire. Safety wise this is NOT an issue BUT it may be interfering with the trouble shooting voltage readings IF the GREEN GROUND wire is OPEN and not grounding the trailer
Jan-05-2019 01:02 PM
Jan-05-2019 12:19 PM
Jan-05-2019 11:31 AM
CA Traveler wrote:Harvard wrote:There are multiple circuits on the CG distribution center and those circuits contribute to the N to G voltage difference. Meanwhile your circuit can have 0A and show a 1.3V voltage difference.
The N to G voltage of 1.3VAC would be abnormal if there is very little current in the Neutral wire. So if there is little or no Neutral current then that 1.3 VAC N to G is likely the problem.
So a 1.3V difference does not indicate a problem unless you know the entire circuit configuration.
BTW Trailers often have additional jacks touching the ground as welll as many MHs.
Jan-05-2019 10:42 AM
Jan-05-2019 10:36 AM
Jan-04-2019 06:32 AM
Chakara wrote:
Thanks everyone. I went through the majority of these recommendations and worked with support over at Progressive. They are shipping out a new unit.
If it is a "weak" ground or neutral - I guess I'll find out after going through the pain of swapping it out 🙂
-Kyle
Jan-03-2019 02:26 PM
Jan-02-2019 03:20 PM
Jan-02-2019 11:08 AM
Chakara wrote:
Ok - I thought those were normal readings - thank you for confirming that Harvard!
The EMS still shows E-2 and PE-2. E-2 implies the problem still exists.
I'll get in there and do some "wiggling" of my install to confirm everything is tight and consistent, but I'm really thinking I got a defective EMS here......
-Kyle
Jan-02-2019 08:30 AM
Jan-01-2019 07:44 PM
