120 Volt Breaker Issue
trailrider
Two breakers in the equation. 15 amp breaker runs the refrigerator outlet. Another 15 amp breaker runs the microwave. The refrigerator breaker trips occasionally when running the microwave. Messed around with the breakers and here is where it gets weird. The refrigerator breaker feeds the microwave breaker somehow. If the refrigerator breaker is off, the microwave breaker doesn't supply power to the microwave when you flip the breaker on. How is this even possible?
2020 Chevrolet Silverado 3500HD GAS!!!
1978 Chevrolet Silverado K20 4x4
2007 Komfort 277TS
2020 Sherco 300 SEF Factory
2018 Honda Rancher TRX420FA6
2017 Montesa 4RT260
2021 Honda CRF450X
26 REPLIES 26
trailrider
And just to explain it a different way. All breakers are on.
Turn off microwave breaker, microwave display goes out.
Turn off refrigerator breaker, microwave display goes out and refrigerator 120 volts outlet is dead. Verified because refrigerator switches to gas mode.
And since the refrigerator breaker is tied to both outlets for the refrigerator and the big convection oven/microwave this 15 amp breaker will trip occasionally. Which my guess is if the 300 watt refrigerator heating element happens to be on at the same time the microwave is in use it trips.
2007 Komfort 277TS
2017 Montesa 4RT260
2021 Honda CRF450X
BFL13
The Canadian version of the 03 Komfort has the MW and water heater on the same 7355 circuit and the one breaker, but there is only the one black wire going to the bottom of that breaker. There is another wall switch that has three positions for the WH and MW, which are : WH, Off, MW.
The USA version of the 03 Komfort 7355 does not have that, but has a different arrangement for the 120v breakers, and uses 20s instead of 15s a lot.
Perhaps the now gone RV had something like that with a downstream switch between the MW and the fridge, away from the single breaker.
EDit--ok forget that, the MW had its own breaker.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
trailrider
enblethen wrote:
30 amp fed from inverter?
Make and model of "inverter"?
This is in an 03 Komfort?
This was on a diesel pusher motorhome that I checked out briefly for someone passing through. It's gone now so I can't look at it again. I was just trying to see if anyone had run across this specific problem so I could learn something. I just don't see how it's possible in a breaker panel when each breaker is supplying it's own specific outlet.
2007 Komfort 277TS
2017 Montesa 4RT260
2021 Honda CRF450X
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
trailrider
enblethen wrote:
Look for the larger #10 wire coming from the shore power cord. Many go to the screw terminal on a 30 amp breaker. This feeds the rest of the breaker via the buss work.
The screw terminals on the 15 amp breakers feed the device/receptacle.
I am guessing that some one replaced the 30 amp breaker with a fifteen amp.
This has a 30 amp breaker on the far left side that is fed from the inverter.
2007 Komfort 277TS
2017 Montesa 4RT260
2021 Honda CRF450X
trailrider
BFL13 wrote:
trailrider wrote:
It is a 30 amp sub panel fed from the inverter. I already took the cover off and verified that each breaker is wired to it's own separate romex. Once those romex leave the box I have no idea what happens down the line.
"Verify" means turn everything off and see what works and doesn't work when you turn on each breaker. Takes a few minutes. Take notes each time. You could be surprised! ๐Ÿ˜ž (Trust but Verify!!!!)
Yeah, I already did that.
2007 Komfort 277TS
2017 Montesa 4RT260
2021 Honda CRF450X
enblethen
Bud
USAF Retired
Pace Arrow
BFL13
Photo in Profile
trailrider
2007 Komfort 277TS
2017 Montesa 4RT260
2021 Honda CRF450X
BFL13
You need to expose the breakers by removing the cover plate. OK, now look at the black wires going into the bottom of each breaker. Sometimes there will be two black wires going to a breaker, so it "shares" circuits.
If that is what is going on here, you can snip black wires and shuffle which goes to which breaker to achieve a more happy combo.
The OEM labelling as to what breaker does what cannot be trusted---verify, and re-label as required
Photo in Profile
Boon_Docker
Sounds like someone was trying to connect two 15 amp breakers to make it 30 amps, but wired them in series.
Matt_Colie
Trail,
How many breakers do you have?
Are they in a distribution panel?
Is the unit a 30Amp service?
I think something is seriously screwed up, but I sure can't tell from here exactly what it is.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
