Connect a 100 watt lamp between chassis and ground.
One hopes you will see no light, try a night light (7 watt kind) as well.
There are several conditoins, Now 120 volt is .. not common, but 60 is very common if you have an open ground, and with most generators you do, however the generator shoudl NOT be grounded so you should still have zero volts.
