โApr-01-2017 09:25 AM
โApr-14-2017 08:36 AM
โApr-14-2017 08:15 AM
โApr-13-2017 08:08 PM
โApr-13-2017 07:31 PM
BFL13 wrote:
With only two batteries you are at risk of having to make toast with the bread-burning rack that goes on the propane stove that sets off your ceiling fire alarm every time, making the dogs bark like crazy, waking up the entire campground.
โApr-13-2017 06:55 PM
MrWizard wrote:
that should work, the specs look good, weight 19.5 pounds
wight means a good transformer inside
โApr-13-2017 06:48 PM
โApr-13-2017 06:29 PM
โApr-13-2017 06:07 PM
DiskDoctr wrote:
Please check me before I commit to it...
My microwave is 1500watt, 13amp, according to its sticker.
If I get an 1800watt continuous inverter, it is listed at 15amps, will it work for my microwave?
I know MOTORS require more power to start, but know very little about microwave ovens.
I only want to buy ONE inverter. I'd rather throw $200 at an extra set of batteries later if we want to run the microwave as a habit than need to replace the inverter.
If the 1800watt will do it, I'll get it tomorrow.
Thanks!
โApr-13-2017 04:03 PM
โApr-13-2017 02:48 PM
โApr-13-2017 02:33 PM
โApr-10-2017 04:47 AM
โApr-09-2017 12:20 AM
โApr-08-2017 08:01 PM
MEXICOWANDERER wrote:
My Samlex is a great 300 watt PSW and it's idle draw is next to nothing. It is a heavy transformer inverter.
The 3000 watt inverter mentioned well above is intriguing. The vendor is claiming Siemens transistors and a Japanese toroid. Not even the old Trace inverters had toroids.
Tear that inverter down! Strip the heat sink! Send it off to be hard black anodized! 137% more heat radiation. A 60-amp 1250 volt full wave bridge rectifier. Chuck the receptacles. Replace with Hubbell 20-amp Nylon units. Remount FETs with silver bearing thermal grease. Mount exterior 50-amp DPDT contactor. Two EB Pabst 120 vac 180 CFM fans mounted exterior. One in and one out flow. Keep that toroid cool. But I do not know the menu format. All the above is a bunch of hot air without knowing if the Vabs max can be time adjusted and Vabs limit set. Same for float. Does is have a feeler-tickler circuit to detect loads for auto turn on? What is the transition time in milliseconds for line to UPS flop-over?
Time to write vendor and decipher Chinglish answer.
And LOSE that Barnum & Bailey paintjob
