2- 6 volts batteries
larry_barnhart
Never had or wanted 2 6 volt batteries but now we have this setup.
I have a viair 12 volt air compressor. My question is how to connect the clips to use the compressor, I am thinking a red to one battery and a black to the other???? chevman 2021 Jayco white hawk TT
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
6 REPLIES 6
wa8yxm
Simply put I will draw an ASCII picture
-{6v}+~-{6V}+12 volts
so your black lead to the - on the left in this drawing
the Red to the +12
(The "~" sign in the drawing is a jumper wire)
That easy
And though they are indeed a pair of six volt batteries when you are lugging them outside the RV. Think of them as a SINGLE 12 volt when installed. for that is what they are..
Many questions like "Can I replace just one?" are answered if you think of them as a single battery (Can you replace just half a 12 volt battery?
See how that works
Can they be "Different" (Makes sizes ages) Woudl you want that a half and half 12 volt battery?
valhalla360
Nomad III
Nomad III
FLY 4 FUN wrote:
If your air compressor has alligator clips you attach pos to pos of one batt and neg to neg of other battery. You made a 12v battery bank by putting twin 6v into series.
This could work or might not depending on which posts you connect to.
Basic setup:
- The ground (negative) cable from the rig will attach to battery 1 Negative post.
- Battery 1 positive will connect to Battery 2 negative.
- Battery 2 positive will connect to the positive cable to the rig.
You connect posts that have the cables coming from the rig. If in doubt, put a multimeter on the posts to find which combination has 12 volts.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
time2roll
larry_barnhart
Thanks I guess I had it correct but nice to have others information.
chevman
chevman
prodigy
scanguage II
TD-EOC
TST tire monitors
FMCA # F479110
Old-Biscuit
YEP....
That way you get 12VDC and draw is from both 6Vs
FLY_4_FUN
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
2015 Brookstone 315RL
2009 Colorado 29BHS (sold 2015)
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
