2 pin panel-mount electrical socket and plug?
maillemaker
Hoping you electrical experts can point me to something non-RV related.
I just bought a pull-behind sprayer for spraying weed killer in my yard. It has a 12V pump on it spray the chemicals. Not sure how much current it draws. I'll be pulling it behind my garden tractor.
This is it: https://smile.amazon.com/gp/product/B00YEQ45PC
It comes with alligator clips to attach to the power source (battery).
My battery is under the tractor seat and I'm afraid if I clip connectors onto it they will touch the metal bottom of the seat and short out. Plus it's not easy to turn the pump on and off while driving the tractor that way.
So I'm going to install a 12V rocker switch on the dash of the tractor, and then I want to install a panel-mount socket and plug on the back of the tractor.
So I'm looking for a panel-mount connector for this purpose. 2 pin.
Any suggestions?
Thanks,
1990 Winnebago Warrior. "She may not look like much but she's got it where it counts!"
7 REPLIES 7
enblethen
The pump should not draw any where the amperage that is being posted. Most of the pumps are simply and 12 volt transfer pump similar to the demand pump used in many RVs. My pump is a ShurFlo 3.8 gallon with no pressure switch.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
wborst
Go to a boat shop and purchase a connector for a trolling motor. They can carry up to 30 amps.
This part and This part.
Brenda, Bill
Our little dog Madison has crossed the Rainbow Bridge
2003 Newmar Mountain Aire 40ft. Spartan chassis
400 hp Cummins ISL
wa8yxm
https://www.northerntool.com/images/downloads/manuals/282780.pdf
Says it draws 8 amps running,. Likely up to 40 starting
Anderson power poles Get 'em from WestMountain Radio and a roll of 10 ga wire Be sure to fuse the leads at the battery Power poles come in many assorted flavors You can get 'em with leads attached (easiest) I have the tool to attach them. You can get 'em in a round snap in assembly I'd support the tractor to trailer line after the power connection (They are easy to pull apart) they are also "Asexual" that is there is no male and female
alternative is the good old reliable flat 2 connetor (Like the flat 4 trailer connector used on small trailers without brakes but onlky 2 pins)
I like the power poles though Use a lot of 'em.
You can also get heavier ones at NAPA Same general design but way heavier. These are often used on tow trucks for the jumper cables.
ndrorder
Norther Tool lists the same sprayer that has a pump with an 8 amp draw. Anderson is good. Might be able to get away with SAE solar connectors such as:
https://smile.amazon.com/CERRXIAN-Weatherproof-Sidewall-Disconnect-Harness/dp/B07TB7XH2H/ref=sr_1_4?dchild=1&keywords=sae+flush+mount&qid=1586789654&s=lawn-garden&sr=1-4
__________________________________________________
Cliff
2011 Four Winds Chateau 23U
DennisVR
I did the same thing with my sprayer. I searched Amazon for a 2 prong 12 volt plug and got the one that has # 10 gauge wire.
enblethen
I used a standard two wire connector from auto parts store.
Bud
USAF Retired
Pace Arrow
stang37
Take a look at this. Anderson-Power-Products/3-6055P2
