I am not familiar with Ram charge setup, but some others, you need to add a fuse under the hood to activate the charge line.
You should be able to check at the 7-pin connect, to see if a charge/battery line has power. My Ford, the truck needs to be running, for battery wire to be live.
If your camper battery is low, it will take quite a while, for the truck to charge it.
Jerry
