4 Batteries connection schematic
Carlos___Ranae
Decided to replace all four batteries and forgot to take picture of the connections.
Can someone with a 2017 Jayco Seismic 4212 please post a picture of the correct way to connect the four batteries. They are stacked up on two separate trays.
We are on the road and most time no access to internet, so thank you in advance for responces.
Carlos & Ranae
2017 Seismic 4212
2012 Dodge Ram, 3500 Laramie Longhorn
4X4, DWR, Pullrite 18KSuperslide Hitch
2006 Yamaha Midnight Silverado, 1700 CC
6 REPLIES 6
2oldman
That's the easy part. Now you have to know which trailer wires go where on the batteries.
Carlos___Ranae
Thank you for all the responces. The diagram is great. Already saved for future references.
Carlos & Ranae
2017 Seismic 4212
Almot
What KD4UPL said.
Also, they will last longer if you take efforts to wire them in a balanced manner as on the diagram below.
Or, the 2nd best, an almost balanced wiring - diagram below:
And, lastly, how you should not connect them - diagram below. It is still "correct" but terribly imbalanced:
For those who are interested why, here it is: http://www.smartgauge.co.uk/batt_con.html
KD4UPL
Then hook all the positives together and all the negatives together.
Carlos___Ranae
We have four 12 volt batteries.
Carlos & Ranae
2017 Seismic 4212
Artum_Snowbird
It's critical to know whether you have 4 - 12 volt batteries, or 4 - 6 volt batteries.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
