5th axle/hub/wheel?
Casinojunkie
Upon arriving in the RGV I noticed I had totally burnt up a rear axle bearing on my 5th wheel.
The hub and wheel were at a 45* angle, axle had been very hot and rolled end of axle up around axle nut.
Axle and hub needs to be replaced, wheel lug nuts were tight and holes not oblong. Question is do you believe the wheel has been compromised by the heat, can I trust it not to flex?
Thank you.
1997 Dodge Ram 3500 Diesel, automatic, pyro-boost-tranny temp on pillar mount, 354 rear gears, prodigy brake control,
2002 26' Lakota 5th wheel, 3-slide, by McKenzie
3 REPLIES 3
Casinojunkie
golf_bears wrote:
Steel, aluminum, or other metal type wheels?
TucsonJim
I'd take your wheel to your local tire shop and ask them to put it on the spin balancer. If it runs true, it's doubtful it's been damaged.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
golf_bears
