โMar-20-2021 10:08 PM
โMar-26-2021 08:20 PM
โMar-21-2021 06:00 PM
dougrainer wrote:
If you have it at the rear area, then the test drive is not needed. Are you POSITIVE the bubbles have not been there since day 1? Doug
โMar-21-2021 04:52 PM
โMar-21-2021 09:57 AM
dougrainer wrote:
I want you to take the 5th wheel and drive 60 mph and have a friend follow you by the side in his auto. Have him get ahead of you and be able to observe the front roof top cap and see if he sees the rubber billowing up in the front. IF this front area behind the front cap are the only bubbles, odds are air is getting under that front cap seam. When this happens the front seam appears to be tight with no gaps. But at 60 mph, the air does get under and cause this type problem. I did not realize until I read your post again that the bubbles appear only in the front few feet. I thought you had this all over the complete roof, which is why I stated cleaning products. Doug
โMar-21-2021 09:11 AM
โMar-21-2021 08:38 AM
ken56 wrote:
Only idea is to take it back to your dealer and make a claim on a bad installation. Unfortunately you have to have the dealer document it and have them work with the manufacturer. The only think I believe if could possible be is a bad original install at the factory.
โMar-21-2021 08:33 AM
dougrainer wrote:
The most common cause of this mass of bubbles is a Incorrect use of a roof cleaning product. The product had some petroleum distillates in it and that is a no-no for EPDM roofs. Bubbles will NOT let water penetrate. Another possible cause, but rare for all those bubbles, is a roof edge seam is not sealed and when in transit air is getting under the membrane. But this usually causes a few LARGE bubbles. Doug
โMar-21-2021 06:50 AM
โMar-21-2021 05:00 AM
