A/C Compressor not kicking on after Thermostat install.
I just replaced my duo-therm thermostat on my Roo 233 with a honeywell th6110d102 because the temp control in the old one was going bad. I hooked it up as follows
wire +7.5 Red - No Connections
Cool Yellow - Y
Fan Brown-G
Hi fan Blue - toggle switch back to G
Fur White - W
gnu Green to RC that is jumpered to RH
The furnace kicks on fine, the fan runs on low and hi fine. I set the therm. to cool and lower the temp. The A/C unit kicks on but the compressor doesnโt start. I checked the voltage and it is only drawing about 3.2 AMPS. So I went and put the old therm. back in and still the same results. It is pretty cold outside tonight and I am wondering since the old one did the same is there an outside temp where the A/C unit will not kick on at? It worked fine a few days ago but it was much warmer outside. Any ideas? Thanks
Old
photo (1) by
.jasonwNew
photo by
.jasonw
2008 Jayco 1--7
