Low voltage
Put fridge and water heater on propane
Turn on a/c turn on high, temp control to full on
Don't set it to cycle, let it run full cold, continuous
Too cold crack a window
High speed on, will keep the coils from icing up in the high humidity
Always on, the compressor will not have to re start when voltage is low and head pressure is high and hot
Next step is too invest in an auto transformer, , keeps the voltage from dropping too low, maintains a safe level of voltage for the RV
I can explain it to you.
1997 F53 Bounder 36s
