A Project Sitting On A Shelf? Unfinished?
MEXICOWANDERER
Uglier than a mile of mud fence. Already dirty. Camouflage - who'd wanna walk off with it?
Then there's temperature compensation. My way...
5 REPLIES 5
MEXICOWANDERER
Da Boorg. Remember, the chuckles about "projects dreamed about, started, then stalled"?
That 93F is a half mile from the crashing breakers. Not high-plains dust-dry humidity. Temperature compensation valid from El Azizia, Libya 136F, to Vostok Station -90F.
That is my "Something's Afoot" image...
Just got some 140 lm/wt Cree chips. 10 watt. Going to build some direct drive 12 volt 40-watt lamps.
Found a UL registered waterproof driver for the 50 watt UV emitter. Going with Kynar 18/2 power wire.
The six-year-old got nailed by a scorpion day before yesterday. Had to take her to the clinic, screaming. Bad envenomation, foaming out the mouth. That is going to END when that UV light arrives. Hello mass chicken McScorpions.
Tomorrow the 2-channel Spike protector gets affixed to the toad.
Running out of projects...
pconroy328
When it's 93*F inside, you know - I'd prefer not to be reminded by large, blinking numerals on an LCD. ๐Ÿ™‚
MrWizard
Moderator
Moderator
i think that might be 'The Borg' charger
or its baby relative
I can explain it to you.
1997 F53 Bounder 36s
Sloop_Smitten
Is this your latest attempt to reinvent the flux capacitor? :@
1992 Fleetwood Jamboree Rallye 24' M/H
Ford E350 Chassis, 7.5L Engine, E40D Transmission
My other motorhome is a 1978 Catalina 25 Sailboat
Cruising Califonia, Sailing the Pacific!
gotsmart
Those toes look pretty clean to me.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
