Sep-22-2021 06:35 AM
Sep-22-2021 04:07 PM
pianotuna wrote:
noteven,
Or you could simply use SiO2 batteries that are not fussy. They can be discharged farther down than Li and can be charged at -40.
They are cheaper than Li unless you are "rolling your own Li".
Sep-22-2021 03:24 PM
Sep-22-2021 08:34 AM
FWC wrote:
The discharge low temperature limit is typically not a hard BMS limit (like the low temperature charge limit) and there is nothing that will physically damage the cells if you discharge below -20C. It is just that the cell manufacturers don't test below -20C because few customers care about that. Some do and actually show pretty good performance down to about -45C. They will loose capacity, but not nearly as much a lead acid batteries.
Sep-22-2021 07:07 AM
Sep-22-2021 06:52 AM
