Last August 2018, we traded our 2004 Newmar DS Diesel Pusher for a 2010 Newmar Dutch Aire DP. In the following approximate time frame, 8/10/18-10/15/18, we travelled to no less than 8+- cgs, private & state but mainly private and encountered approx. "26" instances where ac power would shutdown for anywhere from 30 seconds-2 minutes. 99% of the time, the Progressive Dynamic hardwired system would show error message of E4, which is Line 1-Low Voltage. About the third week of Sept, I replaced the Progressive Dynamic EMS & the Transfer with new and noticed the 50A plug showed burn marks on one of the prongs and was loose where it went into the rubber plug itself. Headed towards Tx on about 10/15/19 and stopped at the dealer where purchased for a fridge exchange to a Samsung and had them replace the plug. The shutdowns seemed to stop after the plug was replaced with only error messages showing up after as described. Arrived in southern Tx for the winter and only had (2) issues from 10/20/18-4/26/19. The first was error code E2-Open ground and the second was the E4- low voltage-L2. Left and headed back north on approx. 4/27/19 and stopped at 4-5 CG's with no issues until 6/22/19 at which time we had (1) E4 error message. On 6/25/17, we had an incident of no power when we plugged in and ran generator for 2 hrs before trying the pedestal again. This time we had power. Took to an rv shop and had it checked and of course every thing ran fine. The tech talked with Progressives techs and every thing check ok when he ran there tests. On 6/30/19, no power when plugged in at a KOA in Newton, Ia, Tried another newer pedestal (2) hrs later and the power came on in the coach. In Shipshewana, Ind from 7/1/19-7/8/19 and had one incident where the 50A pedestal breaker tripped when I plugged a small vac into the 20A pluin of the pedestal. Reset and everything ran ok. We are at a cg n Holland, Michigan at this time and have had (1) E4 message only.
Any rv electronic savvy people have any idea(s) what might be causing this fiasco?
2010 Newmar Dutch Aire 4304,Cummins ISL 425hp,Spartan MM Chassis,2013 Chev Equinox AWD Towed,Ready Brute Elite TowBar/Brake,FMCA #402879,SKP#120487
