โAug-13-2018 12:54 PM
โAug-21-2018 07:21 PM
โAug-21-2018 02:28 PM
DAS26miles wrote:
My buddy has the above mentioned MH with the old analog TV and Direct TV and wants to be able to watch it without running the generator. He wants to install a small 400w inverter next to the front TV taping off the 12v wiring above the passenger seat.
โAug-21-2018 01:08 PM
DAS26miles wrote:Blackdiamond wrote:
In the Southwind the batteries are mounted under the entrance stairs. I placed my inverter in the luggage compartment to the left of the door and tapped into the wiring that runs along the passenger side, under the cabinets inside. So I have that whole side of the MH on the inverter except the water heater and microwave. I bought this one, built in transfer switch and a better charger than the one than came with it.Inverter
Blackdiamond The dealer said they would install the inverter in that compartment also. Would be interesting to see how you did the wiring, are you near us in Socal?
โAug-19-2018 07:50 AM
BFL13 wrote:
If that analogue TV is a CRT type, those have a huge start-up surge that makes them difficult to operate from a small inverter and a cig plug level of wiring.
โAug-19-2018 07:18 AM
โAug-19-2018 07:03 AM
โAug-17-2018 04:40 PM
โAug-17-2018 12:59 PM
โAug-17-2018 10:54 AM
pianotuna wrote:I have an old analog TV but have not watched it in over 10 years, my batteries last longer when dry camping that way. I mounted my inverter under my dinette seat drilled a hole in the floor under neath because my batteries are under the floor. I have 2 welding cables 1 1/2 ft long from the batteries to the inverter. It will run the TV, refer and MW while underway. The only thing I use the inverter for today is to vacuum the MH floor.
What is this word "television"? My RV is a tv free zone!
Victron sells a 350 watt PSW for less than $100 usd.Gjac wrote:
You can buy a 1000 watt MSW inverter for less than $100 and mount it next to his batteries and run the whole house with it with an extension cord running back to his genset plug or transfer switch which ever he has. If he has 2 6V GC batteries it would be fine to run his TV from it. I would not pay $3500 to watch just a TV.
โAug-17-2018 09:32 AM
โAug-17-2018 12:30 AM
โAug-16-2018 09:18 PM
โAug-16-2018 09:16 PM
DAS26miles wrote:
He has no place for the inverter/transfer switch in or near the power panel in the bedroom. He's hoping we can just tap into one of the heavy 12 or 14 gauge 12v wires in the above the driver's and passenger cabinets. Looks easy enough except for that TV plug.
Any more suggestions?
โAug-16-2018 07:58 PM
