โJun-15-2017 11:11 AM
โJun-15-2017 01:59 PM
โJun-15-2017 01:31 PM
time2roll wrote:
Does it have a 30 amp RV cord? or just a standard 5-15?
Standard 5-15
What size wire is before the breaker? and after the breaker?
will check, looks like at least 10ga, haven't torn into yet
Do you have an actual list of appliances?Electric/LP Fridge, 3 overhead light fixtures, 3 outlets on 110 circuit
Water pump, stereo, cig lighter, bathroom light, over sink light are on 12v circuit
What do you really expect to run from the outlets?
Nothing major. Maybe phone chargers. In the future wife may want a microwave that runs off genny/shore just in case. She doesn't use a hairdryer/straightener/etc while camping.
Is everything wired on just one branch circuit?
strangely, yes. When plugged into shore power (and no 12v source) I flip the only breaker and it kills all lights, fridge, and outlets.
โJun-15-2017 01:18 PM
โJun-15-2017 12:49 PM
โJun-15-2017 12:44 PM
time2roll wrote:
Is this a 30 amp RV? APS750 is not going to pass through 30 amps.
More like 8 amps so no MW, A/C, hairdryer, or electric water heat.... even when plugged into utility power.
I think you are better to power up one branch circuit (or 2) that handles some light loads. Not power up the entire panel.
https://www.tripplite.com/750w-powerverter-APS750/
โJun-15-2017 12:07 PM
โJun-15-2017 12:06 PM
pianotuna wrote:
Hi,
Be aware that the Trip Lite is a modified sine wave inverter. (and excellent). So don't run any apple products from it, nor computerized things such as heating blankets.
โJun-15-2017 12:04 PM
MrWizard wrote:
Yes 110v power will pass thru while charging the batteries
You will have to set the fridge to LP manually
Because on automatic, it will run using the inverter, when the inverter is turned on for other things
โJun-15-2017 12:02 PM
2oldman wrote:
You are correct. Your fridge will run on gas if you tell it to. Don't add another 12v battery in series. That would be 24v.
โJun-15-2017 11:44 AM
โJun-15-2017 11:39 AM
โJun-15-2017 11:28 AM
