Adhesive
Luke_Porter
I'm trying to adhere a finished wood panel to an island. Liquid nails didn't work. It was still soft after 24 hours.
What would be a good product?
Yep, actually drove to all of these places---in the last eight years. Missed Rhode Island and New Jersey.
10 REPLIES 10
DaHose
It's not cheap, but 3M Fastbond is a great contact adhesive. That's what I used to adhere the outer filon skin and inner lauan when I rebuilt the cabover of my rig.
Water based, easy to apply with a roller and holds like crazy. Water resistant when dried.
Jose
Crazy_Ray
pro flex
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
DrewE
What's the construction of the island?
If it's wood, I'd be tempted to use a pin nailer and possibly even forego adhesive. The pin nails are surprisingly tenacious and very nearly invisible.
Titebond III (or other simialar wood glue) is very strong, but requires pretty decent clamping while drying to work to its best. It's also not too nasty to work with; it cleans up nicely with a damp rag and doesn't tend to turn you into a human post-it note. Practically all modern wood glues are stronger than wood when the joints are fitted and clamped properly. Titebond III is also nice because it is waterproof, or at least as waterproof as wood is, and is approved for indirect food contact (i.e. you can use it to glue up a cutting board).
Thickened epoxy is also very strong and requires less pressure when clamping, but is messier to use, can cause allergic sensitization (so should be used with gloves), and can be nearly impossible to remove if it drips and cures where you don't want it.
I have used some construction adhesive with very good effectโ€”I think it was PL premium. Very strong when dry, and it adhered to aluminum, wood, and styrofoam (and probably most everything else).
Needless to say, a key with most any glue (other than contact cement, I guess) is to properly brace/clamp things while the glue cures.
Houston_Remodel
I never liked LN just for that reason.
We us PL Premium the 3 year stuff mostly as the 8 year is too thick
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
Pangaea_Ron
Bumpyroad wrote:
3M 5200
bumpy
5200 is a great product, but probably overkill and difficult to work with. You will end up with it all over the island, under your fingernails, on your jeans, shirt, and probably behind your ear, We use it for waterproof exterior and marine applications where the best seal and adhesion is required.
I'd use a good quality contact cement on both surfaces.
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
Explorer1016
We have always used liquid adhesive (glue) found in a can (not squeeze bottle)at any Home depot, Lowes, Menards, True Value, whatever you prefer, we would use a small paint roller and apply the adhesive to both surfaces, veneer and cabinet. We always make sure we get the outer edges thoroughly applied. Then after we adhered both pieces together we rolled the outer surface to remove any air entrapment.
Your question wasn't very descriptive or detailed so not 100% sure what you are trying to accomplish.
2008 Host 300 Super 'C'
2008 Ford F-550 Chassis
Diesel
4x4
Lariat crew cab
20' enclosed car hauler/garage
'87 Jeep rock crawler
Turbo'd
westend
Yes, Liquid Nails and other construction adhesive is slow curing and will remain soft for days. It will work but cures slowly. Now that you have it on there, you will either have to remove it if using another adhesive or brace the panel against the island until it cures somewhat.
Titebond III is about the strongest wood glue out there. It cures in less than an hour. Contact cement on both surfaces will adhere instantly, just have to be careful about placement.
Good luck with your project.
'03 F-250 4x4 CC
Trackrig
What's the island top made of? If wood, I'd use Titebond III waterproof wood glue. For large surfaces, use a disposable 3" roller for even and complete distribution. I've used Gorilla Glue also, but it's messier to work with.
I haven't found liquid nails to be worth much except for plywood subflooring installed on floor joists and then the subflooring needs to be screwed down tight.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
Rvpapa
Some do and some don't. There are SIXTEEN different specs of Liquid Nails. Which did you use.
Art.
Bumpyroad
3M 5200
bumpy
