โOct-03-2015 04:04 PM
โOct-04-2015 06:44 PM
โOct-04-2015 06:25 PM
โOct-04-2015 05:46 PM
Rollnhome wrote:
Maybe this will help
โOct-04-2015 05:22 PM
dougrainer wrote:MrWizard wrote:
my understanding. is that a spring pushes the awning out as it unwinds
the motor is used to Retract the awning which winds up the spring
so they all go out faster than they retract/wind-up
sounds like you have either a power problem, not enough voltage to the motor
or a binding problem
i would lube everything you can
and then i would check the wiring to the motor
a corroded or loose ground/negative wire would create a power problem
last choice .. replace motor, probably have to buy the complete assembly-arm section that contains the motor
lets hope you don't need to do that
Not correct. The rear spring pulls IN when retracting. The OP's problem is he has a worn out motor and needs replaced. Regardless of manual or Electric, awning springs always pull IN for retract. Doug
โOct-04-2015 05:30 AM
โOct-03-2015 11:25 PM
โOct-03-2015 10:15 PM
โOct-03-2015 05:30 PM
