Air Conditioning Problems
Grey_Mountain
We are experiencing tripld digit/high 90s heat. Although the controls are set on 68 or so, the coach will no cool down below around 82. Any ideas on a solution?
GM
2006 Discovery 39S Tin Teepee
Honda CR-V Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
15 REPLIES 15
sayoung
Measure the return air temperature then measure the discharge temperature and if about 20 degrees F +- couple a degrees, if so, then move to a cooler climate. If less than say 15D you might have a dirty condenser or possibly low on charge
Have good blinds on the windows, out in sun all day, etc ?
