Parked our coach last July in garage every thing working. Got it out a week a go and the tac and horn aren't working. I checked to see if the alternator was charging. The batteries showed that no charge was being applied. Pulled the alternator out had it tested . It was in good working order. Now what? I will clean and retighten the battery post next. The tac doesn't activate until you reach about 1200 RPMs this normal
95 Safari Ivory Great C0-Pilot 2 Critters Bud & Gitsit
Ask them to check the integrity of the built-in capacitor in the alternator. Even good shops overlook this vital step if they do an on-the-spot repair of an alternator. The symptoms you describe would be especially hard on the capacitor. It acts as a miniature electrical shock absorber.
I want to thank all the posts on my post. They all have been helpful. I did find a rebuilder of gen and alternators and can test at full power. That will be done tomorrow. Thanks again knew you guys could help. Let you know the verdict on the test.
2013 DRV Tradition 360 RSS LED Lighting 570W of ET Solar Panels MorningStar MPPT 45 Wagan 1000W Elite Pro Inverter Duracell EGC2 Batteries with 460 A-H Capacity
I would check the large red wire on your alternator for 14 volts, if you have this voltage or close to it I would suspect it was a bad battery solenoid/isolator. There should be two large posts on the the solenoids/ isolators they should read close to the alternator voltage when energized. I would also clean the battery terminals to make sure corrosion buildup is not preventing the voltage from getting to your batteries. Hope this helps.
I have a "strong" hunch, you should remove the alternator and get it tested correctly. It's worth the "trouble" believe me.
If the alternator was GOOD the tachometer which is a stator tap connection would not be acting weird.
But I agree, checking the BIG STUD and nut that clamps A BIG WIRE on the rear side of the alternator for voltage is a good idea. If a test light or your meter shows voltage the pathway for the alternator to charge is working. BAD ALTERNATOR. Double check. Have it tested CORRECTLY.
What's the voltage at the engine battery? It could be that you have a relay/solenoid that closes when the engine is running. That solenoid could be bad. Trace the battery cable from the battery to the engine compartment to find the solenoid.
The coach we have is a 1995 Safari Ivory. The chassis is a magmun by Safari. I would like to check the out put of the alternator but I'm not sure which pin it is. Looked on you tube but didn't find what I was looking for. I checked the voltage of the batteries with a voltmeter. The batteries read 11.8 volts with the engine running at high idle.
The batteries showed that no charge was being applied What is telling you the batteries are not charging? The chassis dash voltmeter and or the house battery meter?
Pulled the alternator out had it tested . It was in good working order By whom? Was the alternator FULLY LOADED to the limit of its capacity (Example 120 amps for a 120 amp alternator)?
NUMBER ONE Charge the batteries fully Use a voltmeter. How many volts are present at the output stud of the alternator with the engine running.
NUMBER TWO 12.7 volts or less, alternator is BAD, based on the stator tap signal malfunction symptoms of your tachometer. You would get ZERO RPM reading with a bad alternator or bad voltage regulator control harness connections.
NUMBER THREE Parts store alternator test machines are play toys, and the personnel operating them could not rebuild an alternator if their life depended on it. I've spent too much time with know-it-all parts store employees who in fact could not count past ten without unzipping their pants. Go to your yellow pages or search online for AUTO ELECTRIC REBUILDERS in your area. When they answer the telephone ask them if they rebuild their own alternators "on site". If they say yes, ask them how big the motor is powering their alternator test bench. If they do not know, or they say the motor is less than five horsepower, move on down the line.
What happens is this. A bad alternator can fool a parts store alternator "tester" so fast and so thoroughly that it makes a joke out of the whole operation. THE ALTERNATOR MUST BE TESTED TO FULL CAPACITY OF THE ALTERNATOR.
You want an example? A failed (open or shorted) in a Ford 3 or 4G. The alternator will put out ENOUGH amperage to totally pull the wool over the eyes of a parts store alternator "tester". But the failed diode WILL NOT FOOL THE TACHOMETER especially if it has failed in the SHORTED manner.
I have to insert the following out of necessity rather than vanity. The OP may not be aware of my history.
Personally (with my own hands) rebuilt more than ten thousand automotive, diesel truck, commercial fishing vessel, bus, military and aviation (PMA certified) alternators.
Your description of the symptoms raised the hackles on the back of my neck. They do not add up to a parts store play toy machine declaring the alternator as being "good". If you had enough power to start the engine, you have enough power to operate a hall effect (not an alternator stator) powered tachometer. A mechanical drive tachometer would not care.
Many top notch "real" rebuilders produce a product far superior to a parts store "Look! It puts out electricity - box it up" L.A. rebuilt. Many parts store alternators do not charge well at low engine speeds, have daffy duck voltage regulators that have wildly different voltage setpoints than original equipment regulators.
An RV is HARD on alternators. You need the toughest most durable alternator you can lay your hands on. Or, change mounting hardware over to velco and wing nuts for easier monthly guaranteed-for-life replacement.
