โOct-16-2016 06:38 AM
โNov-04-2016 05:35 AM
โNov-04-2016 05:12 AM
โNov-04-2016 04:58 AM
Sam Spade wrote:harold1946 wrote:
Go to batteryuniversity.com and study some more.
It should read 12.24. at 100 percent charge.
And then things just get worse.
Would you care to correct that number so that I don't have to look like the bad guy again ???
โNov-03-2016 03:04 PM
theoldwizard1 wrote:
Does any one know where to buy those sacrificial probes ?
โNov-03-2016 02:56 PM
harold1946 wrote:
As you stated it depends on the chemistry and construction.
โNov-03-2016 10:03 AM
โNov-03-2016 09:37 AM
harold1946 wrote:rjxj wrote:
12.24 is time to recharge. What are we missing here?
My mistake ๐ฎ Should have been 12.73, depending upon which manufacturer one wants to quote.
โNov-03-2016 09:28 AM
โNov-03-2016 08:57 AM
โNov-03-2016 08:23 AM
harold1946 wrote:
Also Trojan does not state when the battery reading was taken. If not after a minimum of 6 hours, preferably 12 hours, the SOC is not regarded as accurate.
For accurate voltage readings, batteries must remain idle (no charging, no discharging) for at least 6 hrs, preferably 24 hrs.-Trojan (and it's for their flooded deep cycle batteries)
โNov-03-2016 07:47 AM
mike-s wrote:harold1946 wrote:It's not clear where you got that number. Trojan says 12.73 V @ 100 percent SOC. Even the source you cited, Battery University, says 12.65 V. Of course, it will vary a bit depending on the chemistry and construction.
A fully charged 12 volt battery/battery bank should meter at 12.73 volts when at 100 percent SOC, after 12 hours of rest with no load.
โNov-03-2016 07:18 AM
A fully charged 12 volt battery/battery bank should meter at 12.24 volts when at 100 percent SOC, after 12 hours of rest with no load.
โNov-03-2016 06:41 AM
โNov-03-2016 06:06 AM
