Another Bracket Search
js415
You folks helped me find the other bracket I was searching for, so I figured I would ask for some help again.
I have been all over Camping World, Tweetys, PPL, and various other trailer parts websites, and for the life of me, I can not find this bracket.
I either am searching in the wrong place, or looking for the wrong terms.
Does anybody here have any idea the correct name of this type bracket and where/if I can find one somewhere?
Thanks,
Jerry
11 REPLIES 11
js415
pirlbeck wrote:
Try searching for "footman loop"
Amazon footman loop
Thanks for the info.
So now I know it's called a Footmans Loop. I still can not find one anywhere pre-made, that I can go ahead and order.
I just went ahead and bought a small splicing bracket and made one myself.
Thanks all,
VoodooMedicineM
yeh that's what I thought it was
Bill and Joey the dog
klutchdust
Grainger or Mc Master Carr would be my choice to look.
maddog348
That is a Footman Loop used for securing items by use of a strap. Offroad stores Marine stores. Home Depot has 'em for $7(Hillman) I got my last ones at TSC for less than a buck apiece. Take a photo with you a lot of young kids have no idea. JM2ยข YMMV
Farmboy666
Amazon footman loop
Problem solved.
pirlbeck
Amazon footman loop
2009 Lance 845
2021 Flagstaff 529RLKS 36'6" fifthwheel
2006 Dodge Ram 2500 Cummins
19.5 Rickson wheels with Michelin XZE tires
Air lift bags with 72000 wireless onboard air
Hellwig Big Wig rear sway bar
Rancho RS9000XL rear shocks
Torqlift tie downs
monkey44
Nomad II
Nomad II
It's just a piece of flat-bar, bent and then shaped on a grinder and drilled out. Very simple to make ... as said above, any fabrication shop can make on in minutes, if you can't do it yourself.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
USAFBILL
A good steel fabrication shop could build you one if you had one for them to look at and measure....Should be reasonable cost.
2003 Cougar 285EFS
2000 Chev 2500 Ex Cab
BarneyS
Moved to Tech Issues forum from DIY.
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
js415
BurbMan wrote:
What is it a bracket for? What does it do?
It's the bottom support bracket that is mounted to the side of a popup trailer.
A small piece of 3/4" pipe slides in it to help hold up an outside table.
The pipe is flattened on each end and slide between the bracket and trailer, and bracket and table top, to hold it in place and support it in place.
The bracket on the trailer is fine. I made her a second table top, and I need another bracket to mount to the bottom of it.
Thanks,
Jerry
BurbMan
