โSep-19-2013 06:29 AM
โSep-20-2013 06:01 AM
โSep-19-2013 04:34 PM
rk911 wrote:
you have me mixed up with someone else, sir. I said no such thing. quite the opposite. someone else claimed that all of the broadcasters had been re-assigned out of the VHF portion of the band into UHF assignments. I pointed out that there are indeed a few stations still in the VHF portion of the band (RF frequencies previously associated with channels 2-13). CBS 2 in Chicago is one. your list simply confirms what I pointed out earlier.
โSep-19-2013 02:18 PM
n7bsn wrote:MNtundraRet wrote:
rk911:
You may be correct that some low power analog stations are still allowed in the channel 2 to 6 band. I was referring to the digital channels being transmitted since we never scan analog unless we find no digital stations.
We were traveling the last few weeks up in the U.P. area of Michigan along the shores of Lake Superior. In the Painted Rocks National Seashore campgrounds and two Michigan State Parks east of there, we picked up CBC channel 2 (analog) out of Canada, using our double-amplified Winegard system. They are still using both analog and digital signals since they are still in the conversion process.
Judging from our government's latest paralysis in getting anything done some analog low power stations may still be there for a while.
Eh, did you bother to look at the data-base I pointed out in my previous post?
List TV stations that broadcast digital signals on RF channel two
KNOP
KJWP
WLBZ
Just as three examples of stations broadcasting digital signals on RF channel two, which you claimed had been "reassigned" to some other service.
โSep-19-2013 02:15 PM
MNtundraRet wrote:
rk911:
โSep-19-2013 02:12 PM
Tom_M wrote:rk911 wrote:This appears to be a frequency allocation table but have no idea how it pertains to the topic.
ATSC signal 3 MHz above lower edge
VHF low-band (band I)
(frequencies in MHz)
Channel
Lower edge
Video carrier
ATSC pilot
Audio carrier
Upper edge
2 54 55.25 54.31 59.75 60
3 60 61.25 60.31 65.75 66
4 66 67.25 66.31 71.75 72
5 76 77.25 76.31 81.75 82
6 82 83.25 82.31 87.75 88
VHF high-band (band III)
Channel
Lower edge
Video carrier
ATSC pilot
Audio carrier
Upper edge
7 174 175.25 174.31 179.75 180
8 180 181.25 180.31 185.75 186
9 186 187.25 186.31 191.75 192
10 192 193.25 192.31 197.75 198
11 198 199.25 198.31 203.75 204
12 204 205.25 204.31 209.75 210
13 210 211.25 210.31 215.75 216
โSep-19-2013 12:58 PM
โSep-19-2013 12:27 PM
MNtundraRet wrote:
rk911:
โSep-19-2013 11:57 AM
โSep-19-2013 11:30 AM
Channel
Lower edge
Video carrier
ATSC pilot
Audio carrier
Upper edge
Channel
Lower edge
Video carrier
ATSC pilot
Audio carrier
Upper edge
โSep-19-2013 11:13 AM
n7bsn wrote:MNtundraRet wrote:rk911 wrote:
there is no such thing as a digital TV antenna (or an high def antenna for that matter) and while many of the stations have migrated to UHF there are still some on VHF frequencies (CBS 2 in Chicago for example). the new Winegard Sensar IV antenna is getting good reviews (despite it's somewhat misleading marketing as receiving all "HD" channels).
BS ALERT!
Channel 2 is actually RF channel 12. As I stated channels 2 to 6 were in the RF spectrum released for other use.
Could you quote the FCC order to back that up.... (hint, you can't)
FCC guide on tv antennas (note it includes 2-6)
Select current channel assigments (note the number broadcasting on 2-6)
โSep-19-2013 09:22 AM
RoyB wrote:
If you want to keep the BATWING antenna then all you need to do is purchase a new BATWING with UHF add-on assy, It will mount to your existing crank-up assy with two pins. Takes all of five minutes to mount....
โSep-19-2013 09:18 AM
BS ALERT!
โSep-19-2013 09:17 AM
MNtundraRet wrote:
Your assumptions are wrong about ALL stations being in UHF. The information found on some advertised antennas is just BS. Only the channels below 7 disappeared...
โSep-19-2013 08:15 AM
