Anybody have experienvce with Bondocker brand chargers
opnspaces
Navigator II
Navigator II
I think my OEM IOTA in my Jayco is starting to fail and I'd like to replace it. At any rate it's not a three stage as Jayco in it's infinite wisdom had the IQ4 port omitted from the original charger for them. So in short I decided it's time to upgrade my original charger to a new three or four stage charger.
I see on Bestconverters.com they push the Boondockers brand of charger although they do offer the progressive Dynamics as well. From my years on this board I know that the Progressive Dynamics is recommended often but a search finds only three obscure references to Boondocker.
So I figured I'd ask here about peoples experiences or thoughts on the Boondocker over the progressive Dynamics?
FWIW I run 2 Costco brand 6 volts and was thinking about going with a 45a changer so my Honda eu2000i can power it. I also hope to add about 275w of solar in the future if that makes any difference.
Thanks
19 REPLIES 19
Dutch_12078
I replaced the failing Magnetek converter in our coach with a Boondocker PM4b a few years ago, and have been very satisfied with the performance.
Dutch
2001 GBM Landau 34' Class A
lawrosa
If yours is pre 2005 with the two leads on back you may find an IQ3 to make it a smart charger..
https://www.ebay.com/itm/IOTA-Engineering-IQ3-Smart-Controller/281927385644?epid=1056997027&hash=ite...
To raise the charging voltage to 14.2 volts on the early
IOTA chargers without the plug-in control jack, just place a jumper wire
on these two screw terminals. This is recommended for use with a
generator to reduce the generator running time. It should NOT
be considered a permanent modification as long term charging
of a 12 volt battery at 14.2 volts can cause over-charging.
The IQ3 Smart Charge Control also uses these two screw terminals
and one of the power output lugs. They have instructions on the control
as to which wire goes where.
The IQ3 smart controller has been out of production since late 2005 and
the factory no longer has them
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
lawrosa
Thanks
The iota can be modified as a 4 stage. Just call iota and they will tell you..
But have you searched on it for the plug in jack?
From iota
If you are using an IOTA DLS Battery Charger that does not feature a Dual Voltage Jack, you can still attach an IQ4 Smart Charge Controller to your system...just contact IOTA's Customer Service Department for assistance.
Why do you think the iota is going? Maybe its just your batterys shot/sulfated...
The boon dockers are auto mode select... Id rather have the button. I can push it and make it go to 14.4...
Plus I think I read the boondockers kick out too soon...
https://www.iotaengineering.com/iq.htm
Mike L ... N.J.
Old-Biscuit
Recently replaced my neighbors piece of junk WFCO 45A with a Boondocker 55A MBA.
3 year warranty..4 stage charging
Simple 2 screw/3 AC wires/2 DC wires-------DONE
This is what I installed and what he paid for it
BFL13
Boondockers are supplied by PowerMax. See the Boondocker link here
http://powermaxconverters.com/
For 6v batts you want the adjustable voltage version so you can meet your battery's specifications for charging and floating, and also to get the fast charging by being able to stay at the set absorption voltage for your entire "50-90"
The Honda 2000 can run a 60 amper no sweat but might struggle with the 75 amper. Go for the 60 so not to waste gen time with only a 45.
I have been using adjustable voltage PowerMax converters since 2011 and am a fan. In some scenarios, some campers might prefer the PD style with the Charge Wizard. Lots of PD fans on this forum. If you get one do make sure to get the version that does 14.8v which your 6s need.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
