I have that system. I also have two A/Cs. only the FRONT one will make the furnace furn. (Is that a word).
Also there is a switch on the furnace itself (outside behind the access panel) this switch does double duty as a circuit breaker.. There is also a fuse in the usual place (Fuse box).
Now you might (or not) hear a relay click likely a few seconds after you select HEAT mode with a temp setting at least 5 degrees above what it is, or more. The Temp sensor for this unit is not (As many think) the remote, it is part of the A/C grill (little yellow tit) so it's warmer up there than it is around your toes. I've had to put a fan on the dang thing to settle it down and make it behave on occasion.
Next: To see if it will work at all:
Press and hold the Furnace button till you hear a BEEP (2nd beep) This will take several seconds. The furnace should come on almost immed.
If that does not work remove the ceiling cover (intake grill, 4 screws, two are hidden by the filter) and look for some BLUE wires coming out of the control box.. If they are not connected, Then that's not what controls the furnace.
