New 6 volt AGM Batteries
Redterpos3
Now after 3 seasons I've replaced my original 24 group 12 volt battery with 2-6 volt AGM (Duracell Platinum) 409 Ah. I'm setting up to do some off-grid camping now that I've gotten used to the full-hookup variety.
My trailer sits in my driveway, and given our cold winters I have taken the battery out each year and put in my basement when the weather gets real cold. I was wondering if this is necessary with AGM's?
I can keep my trailer hooked up 24/7 so the batteries stay topped off.
The Travelin' Terrapins!
2016 Ford F-350 SRW;CC;4x4;172WB;6.7PSD;34,000m
2011 Nash 27T 12,995m
2013 Yr1 30nts 3150m
2014 Yr2 52nts 3365m
2015 yr3 25nts 2260m
2016 yr4 46nts 2500m
2017 yr5 24nts 1720m
2018 yr6 4nts 30m
22 REPLIES 22
red31
In the East they get Deka east penn batteries with Duracell slapped on em
In the West they get JCI batteries with Energizer slapped on em, sometimes Interstate is slapped on em
Redterpos3
Maybe Sam's Club got a deal on mislabeled batteries?? :@
2018 yr6 4nts 30m
time2roll
I saw the same 409 minutes at 25 amps and assumed they are the same internally.
Redterpos3
smkettner wrote:
Specifications
โ€ข1 amp hour rate:103
โ€ข100 amp hour rate:220
โ€ข20 amp hour rate:190
โ€ข3 amp hour rate:145
โ€ข5 amp hour rate:163
โ€ข6 amp hour rate:167.8
โ€ข8 amp hour rate:173.7
โ€ขBattery Electrolyte Composition:Glass Mat
โ€ขBattery End Type:Top Post
โ€ขBattery Purpose: -Starting Lighting Instrumentation
โ€ขBCI Group Size:GC2
โ€ขCCA at 0 degrees F:680
โ€ขFreight Class:65
โ€ขMCA at 32 degrees F:900
โ€ขMinutes at 15 amps:718
โ€ขMinutes at 25 amps:409
โ€ขMinutes at 5 amps:2304
โ€ขMinutes at 50 amps:171
โ€ขMinutes at 75 amps:94
โ€ขMinutes at 8 amps:1409
โ€ขReserve Capacity:380
โ€ขTerminal Type: -SAE
โ€ขVolts:6
Thanks for this, although this is why I get confused researching the batteries! Looks like mine as a different (new/old) label, but seems to be the same, except for the word "platinum" which I'm thinking is hyperbole!
2018 yr6 4nts 30m
MEXICOWANDERER
Do ya need to tie a string to 'em to keep 'em from floating straight up?
NOTICE: Contents may settle during shipping. We no comprende conveyor belt vibrator. That's why when you rip the box open, it's a quarter the way filled.
HUMONGOUS ULTRA GIGANTIC SIZE CANDY BAR. Product occupies a third of the area of the stiff cardboard tray.
DON'T RAISE THE PRICE! Get smart. Reduce the size of the product which reduces shipping costs.
THEY CAN'T THINK TO DILUTE. Offer ten percent anti-freeze and ship distilled water 3/4 the way across the country AND CHARGE THEM FOR IT. The jug is the same color dummy. They have fourth grade reading comprehension skills. Herb, says "blow smoke". Tell 'em we're doing 'em a big favor, convenience wise.
time2roll
Specifications
โ€ขFreight Class:65
โ€ขVolts:6
http://www.samsclub.com/sams/duracell-agm-golf-car-battery-group-size-gc2agm/prod3870119.ip?navActio...
red31
MEXICOWANDERER wrote:
Shhhh!
They don't want anyone knowing the amp hour rate!
nor the weight or dimensions, they are weightless somewhere.
MEXICOWANDERER
Shhhh!
190 CCA? I'd love to have at those batteries for 15-seconds with a 500 amp adjustable carbon pile load tester. Someone was on drugs when they came up with that label.
Idiocy! The CCA label rating means at 50% CCA loading the battery should not fall below 4.8 volts after 15 seconds. 9.6 volts, in series with a 95-amp load?
Told ya, drugs are saturating our society. The Fall Of The Roman Empire second edition.
red31
I think the sticker be wrong on CCA, 190 ah each or 190 ah as a 12v
CCA of 680, 70 lbs each.
http://www.eastpennmanufacturing.com/wp-content/uploads/Marine-Master-Spec-Sheet-0194.pdf
or check the 'intimidator' line links
http://www.eastpennmanufacturing.com/applications/marine/
Redterpos3
Here is what I have.
2018 yr6 4nts 30m
westend
Redterpos3 wrote:
RoyB wrote:
After looking again at some of these batteries I suspect the AH rating you listed is actually referring to something else maybe cranking amps etc...
Sorry, I didn't quote the number correctly. I should have said 409 min @ 25 amps. I do get confused when doing the research on all these batteries, and the things quoted by each manufacturer. You could be close with the weight. I'd say between 60-70lbs!
For comparisons, most use the Amp Hour rate at 20 hr. Is this the battery you have? If so, the 20 hour rating is 190 AH. The weight is 70 lbs.
Since AGM batteries discharge very slow, especially in Winter conditions, disconnecting one of the terminal connections is the easiest storage solution.
'03 F-250 4x4 CC
MEXICOWANDERER
Most of these batteries are specced quite similar.
Redterpos3
2018 yr6 4nts 30m
harold1946
No. And it wasn't necessary with the other ones either.
A fully charged wet cell battery doesn't freeze until about -70 F.
Wrong again!! AGM batteries that are fully charged do not freeze until -85 F.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
