Anyone make solar roof vent?
Rbertalotto
Does anyone manufacture a solar powered roof top vent. Or should I just add a small solar panel to the existing 12v fan already there?
I would imagine the diode in the solar panel would stop any damage to the solar panel when the 12V battery source is being used....
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
3 REPLIES 3
agesilaus
Marine suppliers would have them they are common for boats.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
Rbertalotto
Well...Seems these little fan motors draw .9amps or 108 watts at 12V. Would need a pretty big solar panel to make it work to maximum output.
RoyB
Dartmouth, MA
landyacht318
There are some small solar powered vents, but their air movement is quite small.
I added a 4 inch Nicro solar vent in 2001. By 2003 the motor was ticking loudly. more recently I removed the motor, gutted as much of the airflow restrictions as possible, and force feed it with 2 120Mm computer fans, inline and counter rotating.
http://www.westmarine.com/buy/nicro-ventilation--day-night-plus-solar-vents--P012_363_001_516
I'd not pursue this route again if I had to do it over.
