โNov-04-2016 06:07 AM
โNov-05-2016 04:19 PM
โNov-05-2016 04:08 PM
โNov-05-2016 03:29 PM
โNov-05-2016 02:15 PM
DrewE wrote:I was thinking 2 batteries would take care of the refer, and 2 would take care of the tv and more advanced electronics in a newer MH and the other 2 would put him equal with me but I was thinking wrong.Gjac wrote:
Thanks for all the explanations. I have a friend with a 2012 Pheaton with 6 6v GC batteries in it. He has a residential refer and a lot of electronic devices inside. On the other hand I have a 1996 GBM with 2 6 v GC batteries but very low amp usage water pump and a few lights. When dry camping I go 7 days before drawing down to 50 percent SOC on the other hand he has to run his genset 2 hrs a day to stay above 50 percent. I never could figure out why before I thought his batteries were bad.
The explanation there has much more to do with simple ratios of battery capacity to energy usage. His battery capacity is about three times yours, but his electric usage rather much more than three times your usage. The residential fridge uses somewhere roughly around ten times the electrical energy of your absorption fridge's control board (but, of course, no propane).
โNov-05-2016 08:52 AM
โNov-05-2016 07:46 AM
โNov-04-2016 08:56 PM
Gjac wrote:jharrell wrote:. If the reduced AHs due to the higher discharge rates is not caused by heat what then actualy causes this reduction?Gjac wrote:
I assumed this loss in amp hr capacity was due to heat. If this is true, can one also assume that these higher discharge rates producing more heat also reduce battery life every thing else being equal (still only discharging to 50 percent)?
No in fact Peukert's law does not take into account temperature change from self heating. Temperature does effect capacity but that it is somewhat independent of discharge rate. That is if you keep the batteries cooled to a constant temperature during discharge, capacity will still be reduced according to Peukert's law.
โNov-04-2016 08:42 PM
Gjac wrote:
Say you have 230 amp hrs in 2 6vGC batteries and you discharge at a low amp rate say 1 amp so if you discharge to 50 percent SOC you should have used 115 amps in 115 hrs. If you then discharge at a higher rate say 10 amps would it then take 11.5 hrs to get to 50 percent SOC? Or does the higher discharge rate create more heat and loss occurs during discharge causing batteries to have less amp hrs?
โNov-04-2016 07:57 PM
โNov-04-2016 01:09 PM
BFL13 wrote:
"An amp hr at 12v is 12 watt hrs , an amp hr at 13v is 13 watt hrs"
Wait a sec! That is counting the volts twice or something tricky?
A Watt-hour is (volts x amps) x hour while an amp-hour has no voltage. Or something. ๐
โNov-04-2016 12:49 PM
โNov-04-2016 12:16 PM
โNov-04-2016 11:31 AM
โNov-04-2016 07:47 AM
