INVERTER ISSUE??
NoSnowInAZ
I have a 13 year old Pro Watt 1000 Xantrex inverter.
Recently, it is setting off alarm and yellow light indicating low available voltage. Checked out one year old house batteries and all four are good.
Could it simply be an "old" inverter needing replacement?
Thanks!
As Always..HAPPY MOTORING!
Golden Pup "Molson"
Golden "Summit" - left us wonderful memories 2/11/08
02 Allegro Bay 36
2013 Jeep Wrangler Sahara Unlimited
FMCA
FULL TIME
Never thought it would happen!
8 REPLIES 8
BFL13
NoSnowInAZ wrote:
Well I found the problem - in double checking all the connections even though all the battery post nuts were tight, the positive cable to/from the inverter had a very badly corroded terminal end and was barely hanging on. I keep a few of those copper terminal ends so we were back in business in about 25 minutes.
Thanks for all the input - as always, I appreciate it.
Currently at the beautiful Oasis RV Resort in Vegas.
Thanks for posting back about how you solved it. Not everybody does that. Helps with the knowledge base.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
NoSnowInAZ
Golden Pup "Molson"
02 Allegro Bay 36
FMCA
FULL TIME
enblethen
BFL13: That is quite possible that that item could be failing.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
BFL13
I don't know if this is electrically possible, but if the same appliance that the inverter ran ok now triggers the alarm, then maybe the appliance's wattage has increased due to some wear and tear in it over the years.
Photo in Profile
Gjac
As others have said check the connections. Every time my alarm went off it was corroded connections. The last time this happened and I clean all connections I was ready to replace the inverter when I noticed the internal connection was corroded inside the end terminal. I removed the cable cleaned the terminal and cable end and soldered the terminal on instead clamping. Check to see if any green stuff is growing inside your terminal.
MrWizard
Moderator
Moderator
Yes check it with a load on the inverter, the one that gives the alarm
I can explain it to you.
1997 F53 Bounder 36s
BFL13
With the inverter doing that, compare the input voltage at the inverter's terminals with your own voltmeter to see if it is really as low as the inverter says it is.
If it is that low, then look for loose or corroded wire connections between there and the battery bank.
Photo in Profile
enblethen
I would start by checking voltage with a good meter. Then check all connections.
Check inverter owner's manual to see if it can be reset. Some accomplished by removing DC input for a minute or so, then restarting.
Bud
USAF Retired
Pace Arrow
